주요 콘텐츠로 건너뛰기
Dell Vostro 1700 Keyboard Replacement
필요한 것
  1. Dell Vostro 1700 Keyboard Replacement, Keyboard: 1 단계, 이미지 1/3 Dell Vostro 1700 Keyboard Replacement, Keyboard: 1 단계, 이미지 2/3 Dell Vostro 1700 Keyboard Replacement, Keyboard: 1 단계, 이미지 3/3
    • Use the Plastic Opening Tools to pry off the tab located on the right side of the top face plate.
  2. Dell Vostro 1700 Keyboard Replacement: 2 단계, 이미지 1/1
    • Lift the plate off the laptop from right to left.
    • Pull the plate out and remove it.
  3. Dell Vostro 1700 Keyboard Replacement: 3 단계, 이미지 1/2 Dell Vostro 1700 Keyboard Replacement: 3 단계, 이미지 2/2
    • Remove the four 3mm Phillips #0 screws.
  4. Dell Vostro 1700 Keyboard Replacement: 4 단계, 이미지 1/2 Dell Vostro 1700 Keyboard Replacement: 4 단계, 이미지 2/2
    • Grasp the laptop with both hands as shown.
    • Push the keyboard upwards with your thumbs to disconnect it.
  5. Dell Vostro 1700 Keyboard Replacement: 5 단계, 이미지 1/2 Dell Vostro 1700 Keyboard Replacement: 5 단계, 이미지 2/2
    • Lift the keyboard from the laptop and remove it.
    • Ensure the connector is fully disconnected before lifting the keyboard out.
결론
Nathan Valm
회원 가입일: 03/20/18
735 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team S3-G1, Peak Spring 2018 UMass Dartmouth, Team S3-G1, Peak Spring 2018 회원
UMASSD-PEAK-S18S3G1
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 10
전체 시간: 392
