주요 콘텐츠로 건너뛰기
Dell Vostro 1710 Hard Drive Replacement
필요한 것
  1. Dell Vostro 1710 Hard Drive Replacement, Battery: 1 단계, 이미지 1/2 Dell Vostro 1710 Hard Drive Replacement, Battery: 1 단계, 이미지 2/2
    • Make certain that the power to your laptop is off.
    • Press and slide the two buttons outwards and away from the battery.
  2. Dell Vostro 1710 Hard Drive Replacement: 2 단계, 이미지 1/1
    • Slide the battery away and parallel from the laptop.
  3. Dell Vostro 1710 Hard Drive Replacement: 3 단계, 이미지 1/1
    • Remove the battery from the slot.
  4. Dell Vostro 1710 Hard Drive Replacement, Hard Drive: 4 단계, 이미지 1/2 Dell Vostro 1710 Hard Drive Replacement, Hard Drive: 4 단계, 이미지 2/2
    • Remove the following five Phillips #1 6mm screws.
  5. Dell Vostro 1710 Hard Drive Replacement: 5 단계, 이미지 1/1
    • Lift back cover from the groove on the right side of the cover next to the symbol.
  6. Dell Vostro 1710 Hard Drive Replacement: 6 단계, 이미지 1/2 Dell Vostro 1710 Hard Drive Replacement: 6 단계, 이미지 2/2
    • Pull up on the blue tab that is attached to the ribbon cable to unplug it.
  7. Dell Vostro 1710 Hard Drive Replacement: 7 단계, 이미지 1/2 Dell Vostro 1710 Hard Drive Replacement: 7 단계, 이미지 2/2
    • Remove the three Philips #1 3mm screws.
  8. Dell Vostro 1710 Hard Drive Replacement: 8 단계, 이미지 1/2 Dell Vostro 1710 Hard Drive Replacement: 8 단계, 이미지 2/2
    • Lift and remove the Hard Drive frame by pulling up on the blue tab.
  9. Dell Vostro 1710 Hard Drive Replacement: 9 단계, 이미지 1/2 Dell Vostro 1710 Hard Drive Replacement: 9 단계, 이미지 2/2
    • Remove the two 3mm screws with a Philips #1 screwdriver from the back side of the frame to remove the Hard drive.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jeremy Campeau
회원 가입일: 03/20/18
347 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team S3-G7, Peak Spring 2018 UMass Dartmouth, Team S3-G7, Peak Spring 2018 회원
UMASSD-PEAK-S18S3G7
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 12
전체 시간: 869
