주요 콘텐츠로 건너뛰기
Dell Vostro 1710 Heatsink Replacement
필요한 것
  1. Dell Vostro 1710 Heatsink Replacement, Battery: 1 단계, 이미지 1/2 Dell Vostro 1710 Heatsink Replacement, Battery: 1 단계, 이미지 2/2
    • Make certain that the power to your laptop is off.
    • Press and slide the two buttons outwards and away from the battery.
  2. Dell Vostro 1710 Heatsink Replacement: 2 단계, 이미지 1/1
    • Slide the battery away and parallel from the laptop.
  3. Dell Vostro 1710 Heatsink Replacement: 3 단계, 이미지 1/1
    • Remove the battery from the slot.
  4. Dell Vostro 1710 Heatsink Replacement, Back Panel: 4 단계, 이미지 1/2 Dell Vostro 1710 Heatsink Replacement, Back Panel: 4 단계, 이미지 2/2
    • Unscrew the eight 6mm screws with a Philips #1 screw driver.
  5. Dell Vostro 1710 Heatsink Replacement: 5 단계, 이미지 1/1
    • Lift back cover from the groove on the left side of the cover next to the symbol.
  6. Dell Vostro 1710 Heatsink Replacement, Fan: 6 단계, 이미지 1/2 Dell Vostro 1710 Heatsink Replacement, Fan: 6 단계, 이미지 2/2
    • Unclip the power supply by pulling the cable directly up and out of the socket.
  7. Dell Vostro 1710 Heatsink Replacement: 7 단계, 이미지 1/2 Dell Vostro 1710 Heatsink Replacement: 7 단계, 이미지 2/2
    • Remove the two 3mm screws located around the edge of the fan with a Philips #1 screw driver.
  8. Dell Vostro 1710 Heatsink Replacement: 8 단계, 이미지 1/2 Dell Vostro 1710 Heatsink Replacement: 8 단계, 이미지 2/2
    • Gently lift and pull to the left until the fan is free from the heatsink.
  9. Dell Vostro 1710 Heatsink Replacement, Heatsink: 9 단계, 이미지 1/2 Dell Vostro 1710 Heatsink Replacement, Heatsink: 9 단계, 이미지 2/2
    • Unscrew the four 8mm screws using a Phillips #1 screwdriver until the heatsink is free.
    • The screws do not come out, only loosen.
  10. Dell Vostro 1710 Heatsink Replacement: 10 단계, 이미지 1/2 Dell Vostro 1710 Heatsink Replacement: 10 단계, 이미지 2/2
    • Lift up on the heatsink to remove it from the laptop.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Tangxiao Sun
회원 가입일: 03/19/18
496 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team S3-G7, Peak Spring 2018 UMass Dartmouth, Team S3-G7, Peak Spring 2018 회원
UMASSD-PEAK-S18S3G7
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 8
전체 시간: 285
