소개
The heat sink helps disperse the heat from the laptop, it usually used in conjunction with the fan. If your laptop is overheating, you might need to replace the heatsink. The guide will demonstrate how to replace the heatsink step by step.
필요한 것
Unscrew the four 8mm screws using a Phillips #1 screwdriver until the heatsink is free.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
