소개
In this guide, we will show you how to remove and replace the Memory Module.
필요한 것
Slide the battery lock to the open position.
Slide the battery release latch to the open position.
Slide the battery out of the battery bay.
Remove the two screws that secure the memory cover, then remove the cover and set it aside.
Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the memory module pops up.
Remove the memory module from the connector.
거의 끝나갑니다!
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
