주요 콘텐츠로 건너뛰기
Dell Vostro 3360 Battery Replacement
필요한 것
  1. Dell Vostro 3360 Battery Replacement, Remove the Screw: 1 단계, 이미지 1/1
    • Remove the screw that secures the access panel to the computer.
  2. Dell Vostro 3360 Battery Replacement, Remove the Access Panel: 2 단계, 이미지 1/1
    • Remove the access panel from the computer.
  3. Dell Vostro 3360 Battery Replacement, Remove the Screw: 3 단계, 이미지 1/1
    • Remove the screw that secures the keyboard to the chassis.
  4. Dell Vostro 3360 Battery Replacement, Prying the Keyboard: 4 단계, 이미지 1/1
    • Starting on the right side of the system, use a plastic scribe to pry up the keyboard from the computer.
  5. Dell Vostro 3360 Battery Replacement, Flipping the Keyboard: 5 단계, 이미지 1/1
    • Flip the keyboard over and lay it on the palmrest.
  6. Dell Vostro 3360 Battery Replacement, Lifting the Clip: 6 단계, 이미지 1/1
    • Lift the clip to release the keyboard cable and disconnect it from the computer.
  7. Dell Vostro 3360 Battery Replacement, Disconnecting the Battery Cable: 7 단계, 이미지 1/1
    • Disconnect the battery cable from the system board.
  8. Dell Vostro 3360 Battery Replacement, Remove the Screws: 8 단계, 이미지 1/1
    • Remove the screws that secure the battery to the system board.
  9. Dell Vostro 3360 Battery Replacement, Remove the Battery: 9 단계, 이미지 1/1
    • Remove the battery from the computer.
결승점
다른 2명이 해당 안내서를 완성하였습니다.
Johnathan Hammond
회원 가입일: 02/28/18
44,953 평판
안내서 408개 작성하였습니다
RampUP America, Inc. RampUP America, Inc. 회원
Community
42 회원들
안내서 1,986개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 9
30일 전: 15
전체 시간: 2,355
