주요 콘텐츠로 건너뛰기
Dell Vostro 3450 System Fan Replacement
필요한 것
  1. Dell Vostro 3450 System Fan Replacement, Unlocking the Battery: 1 단계, 이미지 1개 중 1개
    • Slide the left and the right battery release latches to the unlock position.
  2. Dell Vostro 3450 System Fan Replacement, Removing the Battery: 2 단계, 이미지 1개 중 1개
    • Slide the battery and remove it from the computer.
  3. Dell Vostro 3450 System Fan Replacement, Prying the Keyboard: 3 단계, 이미지 1개 중 1개
    • Press the keyboard down. Pry the keyboard with the use of a flat-head screwdriver towards the display to reveal the first keyboard retainer.
  4. Dell Vostro 3450 System Fan Replacement, Prying the Keyboard retainer: 4 단계, 이미지 1개 중 1개
    • Pry up the second keyboard retainer.
  5. Dell Vostro 3450 System Fan Replacement, Pry up the Keyboard Retainer: 5 단계, 이미지 1개 중 1개
    • Pry up the third keyboard retainer.
  6. Dell Vostro 3450 System Fan Replacement, Prying the Retainer: 6 단계, 이미지 1개 중 1개
    • Pry up the fourth keyboard retainer.
  7. Dell Vostro 3450 System Fan Replacement, Pull up the Keyboard: 7 단계, 이미지 1개 중 1개
    • Pull up the keyboard from the palm rest.
  8. Dell Vostro 3450 System Fan Replacement, Release the Latch: 8 단계, 이미지 1개 중 1개
    • Release the latch on the system board connector, then disconnect the keyboard cable.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  9. Dell Vostro 3450 System Fan Replacement, Loosen the Screw: 9 단계, 이미지 1개 중 1개
    • Loosen the screw that secures the memory door.
  10. Dell Vostro 3450 System Fan Replacement, Removing the Memory Door: 10 단계, 이미지 1개 중 1개
    • Pry up the memory door near the screw hole, lift and remove it.
  11. Dell Vostro 3450 System Fan Replacement, Remove the Screw: 11 단계, 이미지 1개 중 1개
    • Remove the screw that secures the optical drive to the computer.
  12. Dell Vostro 3450 System Fan Replacement, Prying the Drive: 12 단계, 이미지 1개 중 1개
    • Gently pry the optical drive out of the computer.
  13. Dell Vostro 3450 System Fan Replacement, Remove the Screws: 13 단계, 이미지 1개 중 1개
    • Remove the screws that secure the optical drive bracket.
  14. Dell Vostro 3450 System Fan Replacement, Removing the Optical Drive: 14 단계, 이미지 1개 중 1개
    • Remove the optical drive bracket from the optical drive module.
  15. Dell Vostro 3450 System Fan Replacement, Remove the Screws: 15 단계, 이미지 1개 중 1개
    • Remove the screws in the battery compartment.
  16. Dell Vostro 3450 System Fan Replacement, Remove the Screws: 16 단계, 이미지 1개 중 1개
    • Remove the screws in the optical drive compartment.
  17. Dell Vostro 3450 System Fan Replacement, Remove the Rubber: 17 단계, 이미지 1개 중 1개
    • Remove the rubber from the bottom base on the right side.
  18. Dell Vostro 3450 System Fan Replacement, Remove the Rubber: 18 단계, 이미지 1개 중 1개
    • Remove the rubber from the bottom base on the left side.
  19. Dell Vostro 3450 System Fan Replacement, Remove the Screws: 19 단계, 이미지 1개 중 1개
    • Remove all the screws from the bottom base.
  20. Dell Vostro 3450 System Fan Replacement, Remove the Screws: 20 단계, 이미지 1개 중 1개
    • Flip the computer around and remove the screws that secures the palm rest.
  21. Dell Vostro 3450 System Fan Replacement, Release the Latches: 21 단계, 이미지 1개 중 1개
    • Release the latches on the system board connector, then disconnect the touch pad cable and the finger printer cable.
  22. Dell Vostro 3450 System Fan Replacement, Release the Latch: 22 단계, 이미지 1개 중 1개
    • Release the latch on the system board connector and then disconnect the power button cable.
  23. Dell Vostro 3450 System Fan Replacement, Disconnecting the Key Cable: 23 단계, 이미지 1개 중 1개
    • Release the latch on the system board connector and then disconnect the hot key cable.
  24. Dell Vostro 3450 System Fan Replacement, Prying the Palm Rest: 24 단계, 이미지 1개 중 1개
    • Pry up the right side of the palm rest.
  25. Dell Vostro 3450 System Fan Replacement, Prying the Palm Rest: 25 단계, 이미지 1개 중 1개
    • Pry up the left side of the palm rest.
  26. Dell Vostro 3450 System Fan Replacement, Prying the Sides: 26 단계, 이미지 1개 중 1개
    • Pry up the sides of the palm rest and remove it from the computer.
  27. Dell Vostro 3450 System Fan Replacement, Remove the Screws: 27 단계, 이미지 1개 중 1개
    • Remove the screws that secure the hinge cover.
  28. Dell Vostro 3450 System Fan Replacement, Press Down on the Hooks: 28 단계, 이미지 1개 중 1개
    • Press down on the hooks highlighted in the image.
  29. Dell Vostro 3450 System Fan Replacement, Removing the Hinge Cover: 29 단계, 이미지 1개 중 1개
    • Flip the computer around and remove the hinge cover from the side.
  30. Dell Vostro 3450 System Fan Replacement, Remove the Screws: 30 단계, 이미지 1개 중 1개
    • Remove the screws that secure the display hinge.
  31. Dell Vostro 3450 System Fan Replacement, Loosen the Screw: 31 단계, 이미지 1개 중 1개
    • Loosen the screw that secures the low-voltage differential signaling (LVDS) cable.
  32. Dell Vostro 3450 System Fan Replacement, Disconnecting the LVDS Cable: 32 단계, 이미지 1개 중 1개
    • Disconnect the LVDS cable from the system board.
  33. Dell Vostro 3450 System Fan Replacement, Disconnecting the Wireless Cables: 33 단계, 이미지 1개 중 1개
    • Disconnect the wireless local area network (WLAN) antenna cable.
  34. Dell Vostro 3450 System Fan Replacement, Remove the Screws: 34 단계, 이미지 1개 중 1개
    • Remove the screws that secure the left hinge.
  35. Dell Vostro 3450 System Fan Replacement, Remove the Screws: 35 단계, 이미지 1개 중 1개
    • Remove the screws that secure the right hinge.
  36. Dell Vostro 3450 System Fan Replacement, Lifting the Display Assembly: 36 단계, 이미지 1개 중 1개
    • Lift the display assembly and remove it from the computer.
  37. Dell Vostro 3450 System Fan Replacement, Release the Latch: 37 단계, 이미지 1개 중 1개
    • Release the latch on the system board and then disconnect the VGA cable.
  38. Dell Vostro 3450 System Fan Replacement, Remove the Screw: 38 단계, 이미지 1개 중 1개
    • Remove the screw that secures the VGA board.
  39. Dell Vostro 3450 System Fan Replacement, Remove the VGA Board: 39 단계, 이미지 1개 중 1개
    • Remove the VGA board from the chassis.
  40. Dell Vostro 3450 System Fan Replacement, Disconnect the System Fan Cable: 40 단계, 이미지 1개 중 1개
    • Disconnect the system fan cable from the system board.
  41. Dell Vostro 3450 System Fan Replacement, Remove the Screw: 41 단계, 이미지 1개 중 1개
    • Remove the screw that secures the system fan.
  42. Dell Vostro 3450 System Fan Replacement, Remove the System Fan: 42 단계, 이미지 1개 중 1개
    • Remove the system fan from the bottom base module.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Johnathan Hammond
회원 가입일: 02/28/18
45,237 평판
안내서 408개를 작성함
RampUP America, Inc. RampUP America, Inc. 회원
Community
43 회원들
안내서 1,985개를 작성함
0 Guide Comments
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 12
전체 시간: 872
