주요 콘텐츠로 건너뛰기
Dell Vostro 3500 CD/DVD drive Replacement
필요한 것
  1. Dell Vostro 3500 CD/DVD drive Replacement, Sliding the Battery Latch: 1 단계, 이미지 1개 중 1개
    • Flip the computer over.
    • Slide the battery release latch to the unlock position.
  2. Dell Vostro 3500 CD/DVD drive Replacement, Sliding the Battery Release Latch: 2 단계, 이미지 1개 중 1개
    • Slide the other battery release latch to the unlock position.
  3. Dell Vostro 3500 CD/DVD drive Replacement, Removing the Battery: 3 단계, 이미지 1개 중 1개
    • Slide the battery and remove it from the computer.
  4. Dell Vostro 3500 CD/DVD drive Replacement, Remove the Screws: 4 단계, 이미지 1개 중 1개
    • Turn the laptop over and remove two screws securing the service cover.
  5. Dell Vostro 3500 CD/DVD drive Replacement, Removing the Base Cover: 5 단계, 이미지 1개 중 1개
    • Prise up the service cover and remove it from the computer. Clips along the edges can be snapped open except for those on the left hand edge (as shown in the photo) which have to be disengaged after all the others by romoving the cover in the direction shown.
    • On resassembly, insert the clips on the left hand edge then snap all te others home by applying firm pressure along the other edges of the cover.
  6. Dell Vostro 3500 CD/DVD drive Replacement, CD/DVD drive removal: 6 단계, 이미지 1개 중 1개
    • Remove a single screw from under the service cover.
    • You should now be able to slide the CD/DVD drive out.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Philip Le Riche
회원 가입일: 02/18/14
30,795 평판
안내서 47개를 작성함
Restart Project Restart Project 회원
Local Repair Groups
23 회원들
안내서 661개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 19
전체 시간: 581
