주요 콘텐츠로 건너뛰기
Dell Vostro 3500 Hard Drive Replacement
필요한 것
  1. Dell Vostro 3500 Hard Drive Replacement, Sliding the Battery Latch: 1 단계, 이미지 1개 중 1개
    • Flip the computer over.
    • Slide the battery release latch to the unlock position.
  2. Dell Vostro 3500 Hard Drive Replacement, Sliding the Battery Release Latch: 2 단계, 이미지 1개 중 1개
    • Slide the other battery release latch to the unlock position.
  3. Dell Vostro 3500 Hard Drive Replacement, Removing the Battery: 3 단계, 이미지 1개 중 1개
    • Slide the battery and remove it from the computer.
  4. Dell Vostro 3500 Hard Drive Replacement, Remove the Screws: 4 단계, 이미지 1개 중 1개
    • Turn the laptop over and remove two screws securing the service cover.
  5. Dell Vostro 3500 Hard Drive Replacement, Removing the Base Cover: 5 단계, 이미지 1개 중 1개
    • Prise up the service cover and remove it from the computer. Clips along the edges can be snapped open except for those on the left hand edge (as shown in the photo) which have to be disengaged after all the others by romoving the cover in the direction shown.
    • On resassembly, insert the clips on the left hand edge then snap all te others home by applying firm pressure along the other edges of the cover.
  6. Dell Vostro 3500 Hard Drive Replacement, Remove the Screws: 6 단계, 이미지 1개 중 1개
    • Remove the screws that secure the hard-drive assembly to the computer.
  7. Dell Vostro 3500 Hard Drive Replacement, Sliding the Hard-Drive Assembly: 7 단계, 이미지 1개 중 1개
    • Slide the hard-drive assembly towards the center of the computer.
  8. Dell Vostro 3500 Hard Drive Replacement, Lifting the Hard-Drive Assembly: 8 단계, 이미지 1개 중 1개
    • Lift the hard-drive assembly up and away from the computer.
  9. Dell Vostro 3500 Hard Drive Replacement, Remove the Screws: 9 단계, 이미지 1개 중 1개
    • Remove the screws that secure the hard-drive bracket to the hard drive
  10. Dell Vostro 3500 Hard Drive Replacement, Remove the Hard-Drive Adapter: 10 단계, 이미지 1개 중 1개
    • Remove the hard-drive adapter from the hard-drive assembly.
  11. Dell Vostro 3500 Hard Drive Replacement, Lifting the Hard-Drive Bracket: 11 단계, 이미지 1개 중 1개
    • Lift the hard-drive bracket up and away from the hard drive.
결론
다른 6명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Johnathan Hammond
회원 가입일: 02/28/18
45,210 평판
안내서 408개를 작성함
RampUP America, Inc. RampUP America, Inc. 회원
Community
43 회원들
안내서 1,985개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 14
지난 30일: 36
전체 시간: 5,483
