주요 콘텐츠로 건너뛰기
Dell Vostro 3558 Hard Drive Replacement
필요한 것
  1. Dell Vostro 3558 Hard Drive Replacement, Unlocking the Battery: 1 단계, 이미지 1개 중 1개
    • Slide the release latch outwards to unlock the battery.
  2. Dell Vostro 3558 Hard Drive Replacement, Removing the Battery: 2 단계, 이미지 1개 중 1개
    • Remove the battery from the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  3. Dell Vostro 3558 Hard Drive Replacement, Access Panel: 3 단계, 이미지 1개 중 1개
    • Remove the screws that secure the access panel to the computer [1].
    • Lift the access panel partially at a 45–degree angle [2].
  4. Dell Vostro 3558 Hard Drive Replacement, Remove the Access Panel: 4 단계, 이미지 1개 중 1개
    • Remove the access panel from the computer.
  5. Dell Vostro 3558 Hard Drive Replacement, Disconnecting the Hard Drive Cable: 5 단계, 이미지 1개 중 1개
    • Disconnect the hard drive cable from the system board and lift it up to remove it from the computer.
    • Remove the screws that secure the hard drive to the computer.
  6. Dell Vostro 3558 Hard Drive Replacement, Lifting the Hard Drive: 6 단계, 이미지 1개 중 1개
    • Lift the hard drive to remove it from the computer.
  7. Dell Vostro 3558 Hard Drive Replacement, Removing the Hard Drive: 7 단계, 이미지 1개 중 1개
    • Remove the screws that secure the hard drive to the bracket.
    • Lift the hard drive from the bracket.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Johnathan Hammond
회원 가입일: 02/28/18
45,210 평판
안내서 408개를 작성함
RampUP America, Inc. RampUP America, Inc. 회원
Community
43 회원들
안내서 1,985개를 작성함
댓글 한 개
Hello. Which hard drive is suitable for replacement of this particular one because mine is no longer working and I don't know anything about hard drive replacements
Noblesse Mukendi - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 11
전체 시간: 940
