주요 콘텐츠로 건너뛰기
Dell Vostro 5459 Memory Module Replacement
필요한 것
  1. Dell Vostro 5459 Memory Module Replacement, Removing the Base Cover: 1 단계, 이미지 1개 중 1개
    • Remove the screws that secure the back cover to the computer.
    • Pry the edges of the back cover from all sides, to release the back cover.
    • Lift the back cover from the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  2. Dell Vostro 5459 Memory Module Replacement, Removing the Battery: 2 단계, 이미지 1개 중 1개
    • Disconnect the battery cable from the connector on the system board [1].
    • Remove the screws that secure the battery to the computer [2].
    • Lift and remove the battery from the computer [3].
  3. Dell Vostro 5459 Memory Module Replacement, Removing the Memory Module: 3 단계, 이미지 1개 중 1개
    • Lift the plastic enclosure covering the top of the memory module compartment.
    • Pull the retention clips from the memory module until it pops up.
    • Remove the memory module from the connector on the system board.
결론
작성자
2다른 기여자 명과 함께
Johnathan Hammond
회원 가입일: 02/28/18
45,555 평판
안내서 408개를 작성함
RampUP America, Inc. RampUP America, Inc. 회원
Community
43 회원들
안내서 1,994개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 5
전체 시간: 328
