주요 콘텐츠로 건너뛰기
Dell Vostro 5510 Speakers Replacement
필요한 것
  1. Dell Vostro 5510 Speakers Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
    • Power off your laptop before beginning disassembly.
    • Place the laptop so the bottom cover is facing upwards.
  2. Dell Vostro 5510 Speakers Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the remaining (M2x4mm) screws with the screwdriver.
    • Loosen the two captive (M2x7.5mm) corner screws with the screwdriver.
  3. Dell Vostro 5510 Speakers Replacement: 3 단계, 이미지 3개 중 1개 Dell Vostro 5510 Speakers Replacement: 3 단계, 이미지 3개 중 2개 Dell Vostro 5510 Speakers Replacement: 3 단계, 이미지 3개 중 3개
    • Pry open the top left corner of the cover with the opening tool.
    • Pry open the top right corner of the cover with the opening tool.
    • Pry the rest of the cover with the opening tool, working in a clockwise motion until it is completely loosened.
  4. Dell Vostro 5510 Speakers Replacement: 4 단계, 이미지 3개 중 1개 Dell Vostro 5510 Speakers Replacement: 4 단계, 이미지 3개 중 2개 Dell Vostro 5510 Speakers Replacement: 4 단계, 이미지 3개 중 3개
    • Lift the cover to remove it from the rest of the laptop.
  5. Dell Vostro 5510 Speakers Replacement, Battery: 5 단계, 이미지 1개 중 1개
    • Unscrew the corner and top middle screws (M2x3mm) from the battery with the screwdriver.
  6. Dell Vostro 5510 Speakers Replacement: 6 단계, 이미지 3개 중 1개 Dell Vostro 5510 Speakers Replacement: 6 단계, 이미지 3개 중 2개 Dell Vostro 5510 Speakers Replacement: 6 단계, 이미지 3개 중 3개
    • Lift the battery to remove it
  7. Dell Vostro 5510 Speakers Replacement, Speakers: 7 단계, 이미지 2개 중 1개 Dell Vostro 5510 Speakers Replacement, Speakers: 7 단계, 이미지 2개 중 2개
    • Remove the 4 mm screw from metal plate above the right-side speaker using a Phillips #0 screwdriver.
  8. Dell Vostro 5510 Speakers Replacement: 8 단계, 이미지 1개 중 1개
    • Disconnect the orange cable securing the speaker cords gently using tweezers.
  9. Dell Vostro 5510 Speakers Replacement: 9 단계, 이미지 2개 중 1개 Dell Vostro 5510 Speakers Replacement: 9 단계, 이미지 2개 중 2개
    • Push the thin white clip back using your finger to release the blue cable.
    • Disconnect the thick blue cable gently using tweezers.
  10. Dell Vostro 5510 Speakers Replacement: 10 단계, 이미지 1개 중 1개
    • Disconnect the thin blue cable by gently pulling with tweezers.
  11. Dell Vostro 5510 Speakers Replacement: 11 단계, 이미지 1개 중 1개
    • Pull the left speaker up using your hand.
  12. Dell Vostro 5510 Speakers Replacement: 12 단계, 이미지 1개 중 1개
    • Pull the right speaker up using your hand.
  13. Dell Vostro 5510 Speakers Replacement: 13 단계, 이미지 1개 중 1개
    • Lift the thin cords from under the cable and other components to disconnect them using your hand.
  14. Dell Vostro 5510 Speakers Replacement: 14 단계, 이미지 1개 중 1개
    • Pull the white part of the box connecting the speaker cords to the computer using your finger.
결론
작성자
1다른 기여자 명과 함께
Simon
회원 가입일: 02/08/24
157 평판
안내서 1개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 4
지난 30일: 6
전체 시간: 78
