주요 콘텐츠로 건너뛰기
Dell Vostro 5510 Touchpad Replacement
필요한 것
  1. Dell Vostro 5510 Touchpad Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
    • Power off your laptop before beginning disassembly.
    • Place the laptop so the bottom cover is facing upwards.
  2. Dell Vostro 5510 Touchpad Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the remaining (M2x4mm) screws with the screwdriver.
    • Loosen the two captive (M2x7.5mm) corner screws with the screwdriver.
  3. Dell Vostro 5510 Touchpad Replacement: 3 단계, 이미지 3개 중 1개 Dell Vostro 5510 Touchpad Replacement: 3 단계, 이미지 3개 중 2개 Dell Vostro 5510 Touchpad Replacement: 3 단계, 이미지 3개 중 3개
    • Pry open the top left corner of the cover with the opening tool.
    • Pry open the top right corner of the cover with the opening tool.
    • Pry the rest of the cover with the opening tool, working in a clockwise motion until it is completely loosened.
  4. Dell Vostro 5510 Touchpad Replacement: 4 단계, 이미지 3개 중 1개 Dell Vostro 5510 Touchpad Replacement: 4 단계, 이미지 3개 중 2개 Dell Vostro 5510 Touchpad Replacement: 4 단계, 이미지 3개 중 3개
    • Lift the cover to remove it from the rest of the laptop.
  5. Dell Vostro 5510 Touchpad Replacement, Battery: 5 단계, 이미지 1개 중 1개
    • Unscrew the corner and top middle screws (M2x3mm) from the battery with the screwdriver.
  6. Dell Vostro 5510 Touchpad Replacement: 6 단계, 이미지 3개 중 1개 Dell Vostro 5510 Touchpad Replacement: 6 단계, 이미지 3개 중 2개 Dell Vostro 5510 Touchpad Replacement: 6 단계, 이미지 3개 중 3개
    • Lift the battery to remove it
  7. Dell Vostro 5510 Touchpad Replacement, Touchpad: 7 단계, 이미지 3개 중 1개 Dell Vostro 5510 Touchpad Replacement, Touchpad: 7 단계, 이미지 3개 중 2개 Dell Vostro 5510 Touchpad Replacement, Touchpad: 7 단계, 이미지 3개 중 3개
    • Disconnect the touchpad from the motherboard using a pair of tweezers.
    • Use a gentle and slow outward movement to minimize the risk of breaking the connection.
  8. Dell Vostro 5510 Touchpad Replacement: 8 단계, 이미지 2개 중 1개 Dell Vostro 5510 Touchpad Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the three 2.2mm screws holding the guard bar in place with the Phillips #0 screwdriver.
  9. Dell Vostro 5510 Touchpad Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the guard bar using a pair of tweezers.
  10. Dell Vostro 5510 Touchpad Replacement: 10 단계, 이미지 2개 중 1개 Dell Vostro 5510 Touchpad Replacement: 10 단계, 이미지 2개 중 2개
    • Unscrew the two 7 mm base head screws from the touchpad with the Phillips #0 screwdriver.
  11. Dell Vostro 5510 Touchpad Replacement: 11 단계, 이미지 1개 중 1개
    • Remove the touchpad from the computer by lifting the side closest to the edge and pulling out.
결론
작성자
1다른 기여자 명과 함께
Emanuel
회원 가입일: 02/08/24
121 평판
안내서 1개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 7
전체 시간: 119
