필요한 것
Unlock the battery by sliding the battery-lock latch towards the outer edge.
Slide the battery-bay release latch and hold it.
Remove the battery from the battery bay.
Remove the two screws from the module cover.
Lift the module cover away from the computer.
Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
Remove the module from the connector.
다른 한 분이 해당 안내서를 완성하였습니다.
