주요 콘텐츠로 건너뛰기
Dell Vostro A860 RAM Memory Sticks Replacement
필요한 것
  1. Dell Vostro A860 RAM Memory Sticks Replacement, RAM: 1 단계, 이미지 1/2 Dell Vostro A860 RAM Memory Sticks Replacement, RAM: 1 단계, 이미지 2/2
    • With the computer facing down locate the RAM compartment cover.
    • Unscrew the two screws holding the cover to the laptop chassis.
    • The screws do not remove completely, they are clipped into the compartment cover.
    • Lift up on the Memory cover and remove.
  2. Dell Vostro A860 RAM Memory Sticks Replacement: 2 단계, 이미지 1/1
    • Using a plastic opening tool push outward on both sides of the RAM stick.
    • doing this will release the silver tension clips holding the memory sticks in place. Once released the stick will easily lift up and out of the unit.
결론
Joshua Dennis
회원 가입일: 03/25/16
528 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 1-5, Miles Spring 2016 UMass Dartmouth, Team 1-5, Miles Spring 2016 회원
UMASSD-MILES-S16S1G5
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 7
전체 시간: 414
