소개
In this guide, we will be showing you how to remove the Solid-State Drive.
필요한 것
Turn the computer over.
Slide the battery-bay release latch and the battery-lock latch towards the outer edges.
Slide the battery out of the battery bay.
Turn the computer top-side up, open the display, and press the power button to ground the system board.
Remove the two screws that secure the solid-state drive.
Lift the solid-state drive out of its system board connector.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 한 개
Remember the add the Warning steps that are found in the Service Manuals at the beginning of the guides.
Terrence15 - 답글
