주요 콘텐츠로 건너뛰기
Dell Vostro A90 Solid-State Drive Removal
필요한 것
  1. Dell Vostro A90 Solid-State Drive Removal, Removing the Battery: 1 단계, 이미지 1/1
    • Turn the computer over.
    • Slide the battery-bay release latch and the battery-lock latch towards the outer edges.
    • Slide the battery out of the battery bay.
    • Turn the computer top-side up, open the display, and press the power button to ground the system board.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  2. Dell Vostro A90 Solid-State Drive Removal, Remove the Screws: 2 단계, 이미지 1/1
    • Remove the two screws on the module cover.
  3. Dell Vostro A90 Solid-State Drive Removal, Lifting the Cover: 3 단계, 이미지 1/1
    • Lift the cover off the computer at an angle as shown in the figure.
  4. Dell Vostro A90 Solid-State Drive Removal, Remove Solid-State Drive: 4 단계, 이미지 1/1
    • Remove the two screws that secure the solid-state drive.
    • Lift the solid-state drive out of its system board connector.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
Johnathan Hammond
회원 가입일: 02/28/18
44,953 평판
안내서 408개 작성하였습니다
RampUP America, Inc. RampUP America, Inc. 회원
Community
42 회원들
안내서 1,986개 작성하였습니다
댓글 한 개
Remember the add the Warning steps that are found in the Service Manuals at the beginning of the guides.
Terrence15 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 15
전체 시간: 186
