주요 콘텐츠로 건너뛰기
Dell Vostro V13 Back Cover and Battery Removal
필요한 것
  1. Dell Vostro V13  Back Cover and Battery Removal, Back Cover: 1 단계, 이미지 1/3 Dell Vostro V13  Back Cover and Battery Removal, Back Cover: 1 단계, 이미지 2/3 Dell Vostro V13  Back Cover and Battery Removal, Back Cover: 1 단계, 이미지 3/3
    • Back up the memory to an external drive and power off the laptop before starting.
    • Flip the laptop over so the vents are facing you.
    • Remove the six 5.0 mm Phillips #1 screws using the magnetic driver.
    • Remove the two 5.0 mm Phillips #1 screws on the back side of the laptop.
  2. Dell Vostro V13  Back Cover and Battery Removal: 2 단계, 이미지 1/3 Dell Vostro V13  Back Cover and Battery Removal: 2 단계, 이미지 2/3 Dell Vostro V13  Back Cover and Battery Removal: 2 단계, 이미지 3/3
    • Slide out the SD and MicroSD holders.
    • If you are having trouble sliding them out, use the plastic opening tool.
  3. Dell Vostro V13  Back Cover and Battery Removal: 3 단계, 이미지 1/3 Dell Vostro V13  Back Cover and Battery Removal: 3 단계, 이미지 2/3 Dell Vostro V13  Back Cover and Battery Removal: 3 단계, 이미지 3/3
    • Slide the plastic opening tool around the perimeter of the laptop until the cover pops off.
    • Pull the back cover off.
  4. Dell Vostro V13  Back Cover and Battery Removal: 4 단계, 이미지 1/2 Dell Vostro V13  Back Cover and Battery Removal: 4 단계, 이미지 2/2
    • Remove the three black 3.9 mm Phillips #1 screws holding the battery in place.
  5. Dell Vostro V13  Back Cover and Battery Removal: 5 단계, 이미지 1/3 Dell Vostro V13  Back Cover and Battery Removal: 5 단계, 이미지 2/3 Dell Vostro V13  Back Cover and Battery Removal: 5 단계, 이미지 3/3
    • Flip up the clip of the ribbon connector.
    • Pull the strip out to disconnect the battery.
  6. Dell Vostro V13  Back Cover and Battery Removal: 6 단계, 이미지 1/2 Dell Vostro V13  Back Cover and Battery Removal: 6 단계, 이미지 2/2
    • Remove the battery.
    • Removing the battery allows you to work safely.
결론
Patrick Swaney
회원 가입일: 01/16/19
363 평판
안내서 3개 작성하였습니다
University of Alabama, Team S2-G1, Bedsole Spring 2019 University of Alabama, Team S2-G1, Bedsole Spring 2019 회원
UA-BEDSOLE-S19S2G1
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 13
전체 시간: 371
