주요 콘텐츠로 건너뛰기
Dell Vostro V13 Back Cover and Battery Removal
필요한 것
  1. Dell Vostro V13  Back Cover and Battery Removal, Back Cover: 1 단계, 이미지 3개 중 1개 Dell Vostro V13  Back Cover and Battery Removal, Back Cover: 1 단계, 이미지 3개 중 2개 Dell Vostro V13  Back Cover and Battery Removal, Back Cover: 1 단계, 이미지 3개 중 3개
    • Back up the memory to an external drive and power off the laptop before starting.
    • Flip the laptop over so the vents are facing you.
    • Remove the six 5.0 mm Phillips #1 screws using the magnetic driver.
    • Remove the two 5.0 mm Phillips #1 screws on the back side of the laptop.
  2. Dell Vostro V13  Back Cover and Battery Removal: 2 단계, 이미지 3개 중 1개 Dell Vostro V13  Back Cover and Battery Removal: 2 단계, 이미지 3개 중 2개 Dell Vostro V13  Back Cover and Battery Removal: 2 단계, 이미지 3개 중 3개
    • Slide out the SD and MicroSD holders.
    • If you are having trouble sliding them out, use the plastic opening tool.
  3. Dell Vostro V13  Back Cover and Battery Removal: 3 단계, 이미지 3개 중 1개 Dell Vostro V13  Back Cover and Battery Removal: 3 단계, 이미지 3개 중 2개 Dell Vostro V13  Back Cover and Battery Removal: 3 단계, 이미지 3개 중 3개
    • Slide the plastic opening tool around the perimeter of the laptop until the cover pops off.
    • Pull the back cover off.
  4. Dell Vostro V13  Back Cover and Battery Removal: 4 단계, 이미지 2개 중 1개 Dell Vostro V13  Back Cover and Battery Removal: 4 단계, 이미지 2개 중 2개
    • Remove the three black 3.9 mm Phillips #1 screws holding the battery in place.
  5. Dell Vostro V13  Back Cover and Battery Removal: 5 단계, 이미지 3개 중 1개 Dell Vostro V13  Back Cover and Battery Removal: 5 단계, 이미지 3개 중 2개 Dell Vostro V13  Back Cover and Battery Removal: 5 단계, 이미지 3개 중 3개
    • Flip up the clip of the ribbon connector.
    • Pull the strip out to disconnect the battery.
  6. Dell Vostro V13  Back Cover and Battery Removal: 6 단계, 이미지 2개 중 1개 Dell Vostro V13  Back Cover and Battery Removal: 6 단계, 이미지 2개 중 2개
    • Remove the battery.
    • Removing the battery allows you to work safely.
결론
작성자
2다른 기여자 명과 함께
Patrick Swaney
회원 가입일: 01/16/19
363 평판
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 15
전체 시간: 507
