주요 콘텐츠로 건너뛰기
Dell Vostro V13 Disassembly
필요한 것
  1. Dell Vostro V13 Disassembly, Dell Vostro V13 Disassembly: 1 단계, 이미지 1/3 Dell Vostro V13 Disassembly, Dell Vostro V13 Disassembly: 1 단계, 이미지 2/3 Dell Vostro V13 Disassembly, Dell Vostro V13 Disassembly: 1 단계, 이미지 3/3
    • Remove the two plastic dummy cards from the laptop.
    • Unscrew the six PH00 screws from the bottom of the laptop.
    • Unscrew the two PH00 screws from the back of the laptop, located at the extreme left and right of the back panel.
    • Slide the bottom cover forward and lift it upwards to remove.
    • You may need to use a strong spudger to create a gap along the base edge - starting from the Ethernet port on the right toward the Kensington port on the left.
  2. Dell Vostro V13 Disassembly: 2 단계, 이미지 1/1
    • Carefully remove the battery connector. It is a ribbon cable that is clamped down. Flick the black clamp up using the edge nearest the battery. The ribbon cable is now free to move for the next step.
    • Unscrew the four PH00 screws from the battery.
    • Lift the battery upwards to remove it.
  3. Dell Vostro V13 Disassembly: 3 단계, 이미지 1/2 Dell Vostro V13 Disassembly: 3 단계, 이미지 2/2
    • Unscrew the four PH00 screws from the hard drive enclosure.
    • To remove the hard drive, gently lift the drive to a shallow upward angle and carefully slide it to the right.
    • To avoid damaging the SATA port, lift the hard drive to a very small angle while removing it!
  4. Dell Vostro V13 Disassembly: 4 단계, 이미지 1/2 Dell Vostro V13 Disassembly: 4 단계, 이미지 2/2
    • Using a plastic opening tool, pry open the top panel containing the power switch. Start with the bottom-right edge closest to the keyboard.
    • Unclip and remove the ribbon from the panel.
    • Always be careful when removing ribbon cables! Try not to bend them unnecessarily. Do not pull them with excess force.
    When you're prying this off it might resist a little more than you'd think it should near where it's held by 2 pressure clips near the center.
    Brett Hoop - 답글
  5. Dell Vostro V13 Disassembly: 5 단계, 이미지 1/2 Dell Vostro V13 Disassembly: 5 단계, 이미지 2/2
    • Remove the two PH00 screws from the keyboard.
    • Gently lift the keyboard upwards and push it towards the screen to remove.
    • Remove the ribbon cable from underneath the keyboard.
  6. Dell Vostro V13 Disassembly: 6 단계, 이미지 1/2 Dell Vostro V13 Disassembly: 6 단계, 이미지 2/2
    • Remove all of the ribbon cables from the motherboard.
    • Take out the one screw from the audio card and then lift upward to remove.
  7. Dell Vostro V13 Disassembly: 7 단계, 이미지 1/2 Dell Vostro V13 Disassembly: 7 단계, 이미지 2/2
    • Unscrew the six PH00 screws from the memory card reader.
    • Place a hand underneath the memory card reader while unscrewing it so that it doesn't fall out.
    • Remove the CMOS battery cable from the motherboard.
  8. Dell Vostro V13 Disassembly: 8 단계, 이미지 1/1
    • Using a small plastic opening tool, gently lift and remove the two antenna cables from the wireless card.
    • Unscrew the one tiny screw securing the wireless card.
    • The wireless card should pop up.
    • Gently slide the card forward to remove it.
  9. Dell Vostro V13 Disassembly: 9 단계, 이미지 1/2 Dell Vostro V13 Disassembly: 9 단계, 이미지 2/2
    • Remove all six screws from the motherboard.
    • Unscrew the two PH00 screws from the cooling fan.
    • Gently lift the motherboard upward and then slide it forward to remove.
    • Be extremely careful with the motherboard!
  10. Dell Vostro V13 Disassembly: 10 단계, 이미지 1/1
    • Push the two metal clips on either side of the RAM outward; the memory chip will pop up.
    • Pull the memory down from the slot to remove it.
  11. Dell Vostro V13 Disassembly: 11 단계, 이미지 1/1
    • Unscrew the four PH1 screws from the heatsink.
    • You may also need to remove the screw on the fan shroud.
    • Pull the heatsink and the fan upward to remove both.
결론
다른 11명이 해당 안내서를 완성하였습니다.
Kevin Dookharan
회원 가입일: 08/23/12
383 평판
안내서 1개 작성함
댓글 2개
is the CPU removable?
Trevor Vuong - 답글
No, it's not. All laptops have soldered ballpoint CPUs and GPUs.
Chris Yang - 답글
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 15
30일 전: 56
전체 시간: 37,874
