주요 콘텐츠로 건너뛰기
Dell Vostro V13 Keyboard Replacement
필요한 것
  1. Dell Vostro V13 Keyboard Replacement, Back Cover: 1 단계, 이미지 1/3 Dell Vostro V13 Keyboard Replacement, Back Cover: 1 단계, 이미지 2/3 Dell Vostro V13 Keyboard Replacement, Back Cover: 1 단계, 이미지 3/3
    • Back up the memory to an external drive and power off the laptop before starting.
    • Flip the laptop over so the vents are facing you.
    • Remove the six 5.0 mm Phillips #1 screws using the magnetic driver.
    • Remove the two 5.0 mm Phillips #1 screws on the back side of the laptop.
  2. Dell Vostro V13 Keyboard Replacement: 2 단계, 이미지 1/3 Dell Vostro V13 Keyboard Replacement: 2 단계, 이미지 2/3 Dell Vostro V13 Keyboard Replacement: 2 단계, 이미지 3/3
    • Slide out the SD and MicroSD holders.
    • If you are having trouble sliding them out, use the plastic opening tool.
  3. Dell Vostro V13 Keyboard Replacement: 3 단계, 이미지 1/3 Dell Vostro V13 Keyboard Replacement: 3 단계, 이미지 2/3 Dell Vostro V13 Keyboard Replacement: 3 단계, 이미지 3/3
    • Slide the plastic opening tool around the perimeter of the laptop until the cover pops off.
    • Pull the back cover off.
  4. Dell Vostro V13 Keyboard Replacement: 4 단계, 이미지 1/2 Dell Vostro V13 Keyboard Replacement: 4 단계, 이미지 2/2
    • Remove the three black 3.9 mm Phillips #1 screws holding the battery in place.
  5. Dell Vostro V13 Keyboard Replacement: 5 단계, 이미지 1/3 Dell Vostro V13 Keyboard Replacement: 5 단계, 이미지 2/3 Dell Vostro V13 Keyboard Replacement: 5 단계, 이미지 3/3
    • Flip up the clip of the ribbon connector.
    • Pull the strip out to disconnect the battery.
  6. Dell Vostro V13 Keyboard Replacement: 6 단계, 이미지 1/2 Dell Vostro V13 Keyboard Replacement: 6 단계, 이미지 2/2
    • Remove the battery.
    • Removing the battery allows you to work safely.
  7. Dell Vostro V13 Keyboard Replacement, Keyboard: 7 단계, 이미지 1/1
    • Open the laptop so the keyboard is visible.
  8. Dell Vostro V13 Keyboard Replacement: 8 단계, 이미지 1/3 Dell Vostro V13 Keyboard Replacement: 8 단계, 이미지 2/3 Dell Vostro V13 Keyboard Replacement: 8 단계, 이미지 3/3
    • Wedge the plastic opening tool around the seam of the notification panel to pop it off.
  9. Dell Vostro V13 Keyboard Replacement: 9 단계, 이미지 1/3 Dell Vostro V13 Keyboard Replacement: 9 단계, 이미지 2/3 Dell Vostro V13 Keyboard Replacement: 9 단계, 이미지 3/3
    • Disconnect the ribbon connector on the panel.
    • Remove the panel.
  10. Dell Vostro V13 Keyboard Replacement: 10 단계, 이미지 1/2 Dell Vostro V13 Keyboard Replacement: 10 단계, 이미지 2/2
    • Remove the two silver 3.1 mm Phillips #1 screws.
  11. Dell Vostro V13 Keyboard Replacement: 11 단계, 이미지 1/2 Dell Vostro V13 Keyboard Replacement: 11 단계, 이미지 2/2
    • Use the plastic opening tool to pry the keyboard out of the laptop.
    • Do not pull the keyboard all the way out yet.
  12. Dell Vostro V13 Keyboard Replacement: 12 단계, 이미지 1/2 Dell Vostro V13 Keyboard Replacement: 12 단계, 이미지 2/2
    • Disconnect the ribbon cable that connects the keyboard to the laptop by flipping up the white locking tab on the ZIF connector.
    • If you're having trouble, use the plastic opening tool to help.
  13. Dell Vostro V13 Keyboard Replacement: 13 단계, 이미지 1/3 Dell Vostro V13 Keyboard Replacement: 13 단계, 이미지 2/3 Dell Vostro V13 Keyboard Replacement: 13 단계, 이미지 3/3
    • Remove the keyboard.
결론
Amy Ledermann
회원 가입일: 01/16/19
361 평판
안내서 3개 작성하였습니다
University of Alabama, Team S2-G1, Bedsole Spring 2019 University of Alabama, Team S2-G1, Bedsole Spring 2019 회원
UA-BEDSOLE-S19S2G1
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 11
전체 시간: 361
