소개
In this guide, we will be showing you how to remove the Battery.
필요한 것
Slide the base cover towards the front of the computer. Lift it up and away from the computer.
If this is all you are doing Follow Step In Reverse if not Go to Next Step.
Lift the black cable-release clip to release the battery cable from the connector on the system board and disconnect the battery cable.
거의 끝나갑니다!
결승점
다른 4명이 해당 안내서를 완성하였습니다.
