주요 콘텐츠로 건너뛰기
Dell Vostro V130 Hard Drive and Audio Board Removal
필요한 것
  1. Dell Vostro V130 Hard Drive and Audio Board Removal, Remove the Screws: 1 단계, 이미지 1개 중 1개
    • Remove the screws that secure the base cover to the computer.
  2. Dell Vostro V130 Hard Drive and Audio Board Removal, Removing the Base Cover: 2 단계, 이미지 1개 중 1개
    • Slide the base cover towards the front of the computer. Lift it up and away from the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  3. Dell Vostro V130 Hard Drive and Audio Board Removal, Disconnecting the Battery: 3 단계, 이미지 1개 중 1개
    • Lift the black cable-release clip to release the battery cable from the connector on the system board and disconnect the battery cable.
  4. Dell Vostro V130 Hard Drive and Audio Board Removal, Remove Battery Screws: 4 단계, 이미지 1개 중 1개
    • Remove the screws that secure the battery to the computer.
  5. Dell Vostro V130 Hard Drive and Audio Board Removal, Lift the Battery: 5 단계, 이미지 1개 중 1개
    • Lift the battery up and away from the computer.
  6. Dell Vostro V130 Hard Drive and Audio Board Removal, Disconnecting the Speaker: 6 단계, 이미지 1개 중 1개
    • Disconnect the speaker and system board cables from the audio board.
  7. Dell Vostro V130 Hard Drive and Audio Board Removal, Remove the Screws: 7 단계, 이미지 1개 중 1개
    • Remove the screws that secure the audio board and the hard drive to the computer.
  8. Dell Vostro V130 Hard Drive and Audio Board Removal, Lifting the Hard Drive and Audio Board: 8 단계, 이미지 1개 중 1개
    • Lift and remove the hard drive and audio board assembly from the computer.
  9. Dell Vostro V130 Hard Drive and Audio Board Removal, Sliding the Audio Board: 9 단계, 이미지 1개 중 1개
    • Slide the audio board from the hard drive.
  10. Dell Vostro V130 Hard Drive and Audio Board Removal, Remove the Screws: 10 단계, 이미지 1개 중 1개
    • Remove the screws that secure the hard-drive bracket to the hard drive.
  11. Dell Vostro V130 Hard Drive and Audio Board Removal, Removing the Hard Drive: 11 단계, 이미지 1개 중 1개
    • Remove the hard drive from the hard-drive bracket.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Johnathan Hammond
회원 가입일: 02/28/18
45,555 평판
안내서 408개를 작성함
RampUP America, Inc. RampUP America, Inc. 회원
Community
43 회원들
안내서 1,994개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 4
전체 시간: 730
