주요 콘텐츠로 건너뛰기
Dell Vostro V131 Hard Drive Removal
필요한 것
  1. Dell Vostro V131 Hard Drive Removal, Removing the Battery: 1 단계, 이미지 1/2 Dell Vostro V131 Hard Drive Removal, Removing the Battery: 1 단계, 이미지 2/2
    • Slide the release latches to unlock the battery.
    • Remove the battery from the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  2. Dell Vostro V131 Hard Drive Removal, Remove Hard Drive Screw: 2 단계, 이미지 1/1
    • Remove the screw that secures the hard drive in place.
  3. Dell Vostro V131 Hard Drive Removal, Sliding the Hard Drive Free: 3 단계, 이미지 1/1
    • Slide the hard drive module to the left.
  4. Dell Vostro V131 Hard Drive Removal, Prying Hard Drive Up: 4 단계, 이미지 1/1
    • Carefully pry up and remove the hard drive from the computer.
  5. Dell Vostro V131 Hard Drive Removal, Removing Bracket: 5 단계, 이미지 1/1
    • Remove the screws which secure the hard-drive bracket to the hard drive. Separate the hard drive bracket from the hard drive.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
Johnathan Hammond
회원 가입일: 02/28/18
44,953 평판
안내서 408개 작성하였습니다
RampUP America, Inc. RampUP America, Inc. 회원
Community
42 회원들
안내서 1,986개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 17
전체 시간: 1,144
