주요 콘텐츠로 건너뛰기
Dell Wyse Xn0m Battery Replacement
필요한 것
  1. Dell Wyse Xn0m Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Identify the location of the battery release switches.
  2. Dell Wyse Xn0m Battery Replacement: 2 단계, 이미지 1/1
    • Slide the left battery release switch to the unlocked position (red showing). This is also indicated by the lock/unlock icons beside the switch.
  3. Dell Wyse Xn0m Battery Replacement: 3 단계, 이미지 1/2 Dell Wyse Xn0m Battery Replacement: 3 단계, 이미지 2/2
    • To remove the battery, pull back the right spring-loaded battery release switch while simultaneously sliding the battery away from the laptop.
    • Reassembly tip: when inserting the new battery, make sure the tracks line up right. The battery tracks should sit on top of the laptop body tracks.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Sam Horne
회원 가입일: 10/30/19
109 평판
안내서 1개 작성함
University of Memphis, Team S2-G1, Kim Fall 2019 University of Memphis, Team S2-G1, Kim Fall 2019 회원
UM-KIM-F19S2G1
4 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 19
30일 전: 33
전체 시간: 1,172
