주요 콘텐츠로 건너뛰기
Dell Wyse Xn0m Fan Replacement
필요한 것
  1. Dell Wyse Xn0m Fan Replacement, Fan: 1 단계, 이미지 1/3 Dell Wyse Xn0m Fan Replacement, Fan: 1 단계, 이미지 2/3 Dell Wyse Xn0m Fan Replacement, Fan: 1 단계, 이미지 3/3
    • Use a spudger to unclip the keyboard from the main body by disengaging the clips lined around the top and sides of the keyboard.
    • Once lifted, push the white slider holding blue ribbon cable and put keyboard to the side.
  2. Dell Wyse Xn0m Fan Replacement: 2 단계, 이미지 1/1
    • With the spudger, remove sliders that are holding the purple ribbon cable.
    • Disconnect cable by the power button.
  3. Dell Wyse Xn0m Fan Replacement: 3 단계, 이미지 1/1
    • Remove the five 7mm Phillips #1 screws underneath the keyboard.
  4. Dell Wyse Xn0m Fan Replacement: 4 단계, 이미지 1/1
    • Close the laptop and flip it over.
    • Remove eight 7mm Phillips #1 screws along the edges of laptop.
    • Put these screws to the side (make sure to keep them apart from keyboard screws).
  5. Dell Wyse Xn0m Fan Replacement: 5 단계, 이미지 1/1
    • After removing the screws, flip the laptop back over and open the screen.
    • Lift the laptop's keyboard/mouse pad top with an opening tool.
  6. Dell Wyse Xn0m Fan Replacement: 6 단계, 이미지 1/2 Dell Wyse Xn0m Fan Replacement: 6 단계, 이미지 2/2
    • Unplug the cable connecting the fan to the motherboard.
    • Lift the tape holding down the cables over the fan.
    • Undo two 5mm Phillips #1 screws.
    • The top left screw is covered by the cables. Use a spudger to get it out of the way.
    • Lift the fan out of its slot.
결론
The process is simple but tedious. Be patient, keep the screws organized, be gentle with the clips and you are good to go!
다른 2명이 해당 안내서를 완성하였습니다.
Daniel Hill
회원 가입일: 10/30/19
172 평판
안내서 1개 작성함
University of Memphis, Team S2-G1, Kim Fall 2019 University of Memphis, Team S2-G1, Kim Fall 2019 회원
UM-KIM-F19S2G1
4 회원들
안내서 3개 작성하였습니다
댓글 한 개
excelent work. thanks for share
Asimple Guy - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 14
30일 전: 30
전체 시간: 981
