주요 콘텐츠로 건너뛰기
Dell Wyse Xn0m Mouse Sensor Board Replacement
필요한 것
  1. Dell Wyse Xn0m Mouse Sensor Board Replacement, Mouse Sensor Board: 1 단계, 이미지 1/1
    • Flip the device over. Unscrew nine marked 7mm Phillips #1 screws.
  2. Dell Wyse Xn0m Mouse Sensor Board Replacement: 2 단계, 이미지 1/2 Dell Wyse Xn0m Mouse Sensor Board Replacement: 2 단계, 이미지 2/2
    • Remove the keyboard by pushing back the tabs at the marked locations with a spudger or plastic opening tool.
  3. Dell Wyse Xn0m Mouse Sensor Board Replacement: 3 단계, 이미지 1/2 Dell Wyse Xn0m Mouse Sensor Board Replacement: 3 단계, 이미지 2/2
    • Turn the device around so the screen is closest to you. Lift the keyboard and detach the ribbon cable with the spudger.
    • To disconnect the cable, disengage the locking tab of the ZIF connector with the spudger and pull the cable out gently.
  4. Dell Wyse Xn0m Mouse Sensor Board Replacement: 4 단계, 이미지 1/1
    • Remove the keyboard and set it aside. Detach the other ribbon cables with the spudger.
    • Remove five 8mm Phillips #1 screws.
  5. Dell Wyse Xn0m Mouse Sensor Board Replacement: 5 단계, 이미지 1/1
    • Pry open the laptop with the plastic opening tool.
  6. Dell Wyse Xn0m Mouse Sensor Board Replacement: 6 단계, 이미지 1/2 Dell Wyse Xn0m Mouse Sensor Board Replacement: 6 단계, 이미지 2/2
    • Under the trackpad, detach the ribbon cables with the spudger.
    • Unscrew two 3mm Phillips #1 screws and lift the board from the pegs.
    • Remove the board from the laptop.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jake Milligan
회원 가입일: 10/30/19
296 평판
안내서 1개 작성함
University of Memphis, Team S2-G1, Kim Fall 2019 University of Memphis, Team S2-G1, Kim Fall 2019 회원
UM-KIM-F19S2G1
4 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 23
전체 시간: 639
