주요 콘텐츠로 건너뛰기
Dell XPS 10 Front and Rear Camera Replacement
필요한 것
  1. Dell XPS 10 Front and Rear Camera Replacement, Front and Rear Camera: 1 단계, 이미지 1/3 Dell XPS 10 Front and Rear Camera Replacement, Front and Rear Camera: 1 단계, 이미지 2/3 Dell XPS 10 Front and Rear Camera Replacement, Front and Rear Camera: 1 단계, 이미지 3/3
    • Unscrew the two screws shown circled in red in the picture.
    • Use a #0 Phillips screwdriver to remove the two 4 mm screws
    • Lift up the plug that connects the camera to the motherboard using the plastic opening tool as shown in the pictures.
  2. Dell XPS 10 Front and Rear Camera Replacement: 2 단계, 이미지 1/2 Dell XPS 10 Front and Rear Camera Replacement: 2 단계, 이미지 2/2
    • After the rear facing camera is removed, you may now remove the front facing camera.
    • Use the nylon spudger to disconnect the cable on the motherboard.
    • Make sure you use the black plastic spudger to pry up the aluminum tape holding the front facing camera. Be careful as the tape is fragile.
결론
James
회원 가입일: 10/04/16
401 평판
안내서 3개 작성하였습니다
USF Tampa, Team 2-1, Nance Fall 2016 USF Tampa, Team 2-1, Nance Fall 2016 회원
USFT-NANCE-F16S2G1
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 299
