주요 콘텐츠로 건너뛰기
Dell XPS 12 9250 Battery Replacement
필요한 것
  1. Dell XPS 12 9250 Battery Replacement, Removing the Back Cover: 1 단계, 이미지 1/2 Dell XPS 12 9250 Battery Replacement, Removing the Back Cover: 1 단계, 이미지 2/2
    • Turn the tablet over.
    • Remove the screws that secure the back-cover assembly to the display assembly.
    • Using a plastic scribe, pry up along the edges of the back-cover assembly.
    • Carefully, lift the back-cover assembly and turn it over.
  2. Dell XPS 12 9250 Battery Replacement, Removing the Battery: 2 단계, 이미지 1/1
    • Remove the screws that secure the battery to the back-cover assembly.
    • Disconnect the battery cable from the system board.
    • Lift the battery, along with its cable, off the back-cover assembly.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Johnathan Hammond
회원 가입일: 02/28/18
44,980 평판
안내서 408개 작성하였습니다
RampUP America, Inc. RampUP America, Inc. 회원
Community
42 회원들
안내서 1,989개 작성하였습니다
댓글 한 개
The 4 screws on the edge are NOT phillips head screws. They appear to be Tork.
ponchojack - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 22
전체 시간: 2,406
