주요 콘텐츠로 건너뛰기
Dell XPS 12 9Q33 Battery Replacement
필요한 것
  1. 주의: 1-3 단계들은 진행 중으로 표시된 안내서에서 제공되었습니다.
    Dell XPS 12 9Q33 Battery Replacement, Back Cover: 1 단계, 이미지 1/1
    • Be sure to power off and unplug your device before you begin your repair.
    • Use your fingers or a spudger to pry up the system badge from the bottom of the laptop.
  2. Dell XPS 12 9Q33 Battery Replacement: 2 단계, 이미지 1/1
    • Use a Phillips screwdriver to remove the eleven screws securing the base cover.
  3. Dell XPS 12 9Q33 Battery Replacement: 3 단계, 이미지 1/1
    • Beginning with the side opposite the power switch, use your fingers to pry up the base cover from the laptop.
    • Carefully lift the base cover around the power switch and remove the cover.
  4. Dell XPS 12 9Q33 Battery Replacement, Removing the Battery: 4 단계, 이미지 1/1
    • Slide the battery cable connector out of its system board socket.
    • Pull parallel to the motherboard, not straight up, or you will damage the socket.
    • Remove the screws that secure the battery to the palm-rest assembly.
    • Lift and remove the battery along with its cable.
    • Slide and hold the power switch for about five seconds to ground the system board.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Johnathan Hammond
회원 가입일: 02/28/18
44,953 평판
안내서 408개 작성하였습니다
RampUP America, Inc. RampUP America, Inc. 회원
Community
42 회원들
안내서 1,986개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 14
전체 시간: 1,095
