소개
In this guide, we will be showing you how to remove and replace the Battery.
필요한 것
1 단계 Back Cover
주의: 1-3 단계들은 진행 중으로 표시된 안내서에서 제공되었습니다.
Use your fingers or a spudger to pry up the system badge from the bottom of the laptop.
Slide the battery cable connector out of its system board socket.
Remove the screws that secure the battery to the palm-rest assembly.
Lift and remove the battery along with its cable.
다른 2명이 해당 안내서를 완성하였습니다.
