주요 콘텐츠로 건너뛰기
Dell XPS 13 9310 Lower Case Replacement
필요한 것
  1. Dell XPS 13 9310 Lower Case Replacement, Unfasten the lower case: 1 단계, 이미지 1/2 Dell XPS 13 9310 Lower Case Replacement, Unfasten the lower case: 1 단계, 이미지 2/2
    • Use a T5 Torx screwdriver to remove the eight 3.3 mm screws securing the case.
  2. Dell XPS 13 9310 Lower Case Replacement, Insert an opening pick: 2 단계, 이미지 1/2 Dell XPS 13 9310 Lower Case Replacement, Insert an opening pick: 2 단계, 이미지 2/2
    • Insert an opening pick between the lower case and the chassis on the front right edge.
  3. Dell XPS 13 9310 Lower Case Replacement, Release the case's front clips: 3 단계, 이미지 1/2 Dell XPS 13 9310 Lower Case Replacement, Release the case's front clips: 3 단계, 이미지 2/2
    • Slide the pick along the front edge to release the clips securing the lower case.
  4. Dell XPS 13 9310 Lower Case Replacement, Release the remaining clips: 4 단계, 이미지 1/3 Dell XPS 13 9310 Lower Case Replacement, Release the remaining clips: 4 단계, 이미지 2/3 Dell XPS 13 9310 Lower Case Replacement, Release the remaining clips: 4 단계, 이미지 3/3
    • Continue sliding the opening pick along the perimeter of the lower case to release the remaining clips.
  5. Dell XPS 13 9310 Lower Case Replacement: 5 단계, 이미지 1/3 Dell XPS 13 9310 Lower Case Replacement: 5 단계, 이미지 2/3 Dell XPS 13 9310 Lower Case Replacement: 5 단계, 이미지 3/3
    • Lift the lower case from the chassis and remove it.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
결론
Take your e-waste to an R2 or e-stewards certified recycler.
Repair didn't go as planned? Try some basic troubleshooting, or ask our Dell XPS answers community for help.
다른 2명이 해당 안내서를 완성하였습니다.
Spencer Day
회원 가입일: 09/14/22
59,678 평판
안내서 430개 작성하였습니다
iFixit iFixit 회원
Staff
141 회원들
안내서 17,895개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 41
30일 전: 123
전체 시간: 1,500
