주요 콘텐츠로 건너뛰기
Dell XPS 13 Display Assembly Replacement
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
필요한 것
  1. Dell XPS 13 Display Assembly Replacement, Back Cover: 1 단계, 이미지 1/2 Dell XPS 13 Display Assembly Replacement, Back Cover: 1 단계, 이미지 2/2
    • Remove the eight 4 mm T5 Torx screws from the bottom cover.
  2. Dell XPS 13 Display Assembly Replacement: 2 단계, 이미지 1/2 Dell XPS 13 Display Assembly Replacement: 2 단계, 이미지 2/2
    • Use a plastic opening tool to pry open the 'XPS' flap in the middle.
  3. Dell XPS 13 Display Assembly Replacement: 3 단계, 이미지 1/1
    • Remove the single Phillips screw hidden beneath the flap.
  4. Dell XPS 13 Display Assembly Replacement: 4 단계, 이미지 1/1
    • Use opening picks or a plastic pry tool to pry open the case clips, beginning from the back edge.
  5. Dell XPS 13 Display Assembly Replacement: 5 단계, 이미지 1/1
    • Remove the bottom cover.
  6. Dell XPS 13 Display Assembly Replacement, Battery Disconnection: 6 단계, 이미지 1/2 Dell XPS 13 Display Assembly Replacement, Battery Disconnection: 6 단계, 이미지 2/2
    • Pull the battery cable connector towards the battery to disconnect it from its socket.
    • If the connector is stubborn, push a little at one side, then the other, to "walk" it out of its socket.
    • If you have trouble walking the connector out of the socket, use the point of a spudger to gently push on the connector indent to slide the connector out.
    • Do not pull up.
    • Open the display and press the power button for five seconds to drain any remaining charge from the system.
  7. Dell XPS 13 Display Assembly Replacement, Battery: 7 단계, 이미지 1/2 Dell XPS 13 Display Assembly Replacement, Battery: 7 단계, 이미지 2/2
    • Remove the four 3 mm Phillips #0 screws located on each corner of the battery.
  8. Dell XPS 13 Display Assembly Replacement: 8 단계, 이미지 1/2 Dell XPS 13 Display Assembly Replacement: 8 단계, 이미지 2/2
    • Do not pull up.
  9. Dell XPS 13 Display Assembly Replacement: 9 단계, 이미지 1/1
    • Peel up any tape securing the speaker cables to the battery.
    • You do not need to remove the speakers, only the tape, allowing the battery to be removed out under the speaker cables.
  10. Dell XPS 13 Display Assembly Replacement: 10 단계, 이미지 1/1
    • Remove the battery.
  11. Dell XPS 13 Display Assembly Replacement, Display Assembly: 11 단계, 이미지 1/3 Dell XPS 13 Display Assembly Replacement, Display Assembly: 11 단계, 이미지 2/3 Dell XPS 13 Display Assembly Replacement, Display Assembly: 11 단계, 이미지 3/3
    • Pull the sliding touchscreen connector gently to the right and out of the motherboard.
  12. Dell XPS 13 Display Assembly Replacement: 12 단계, 이미지 1/2 Dell XPS 13 Display Assembly Replacement: 12 단계, 이미지 2/2
    • Use your fingers to remove the sliding camera connector out from the motherboard.
  13. Dell XPS 13 Display Assembly Replacement: 13 단계, 이미지 1/2 Dell XPS 13 Display Assembly Replacement: 13 단계, 이미지 2/2
    • Pop the coaxial antenna cables up from the wireless card with the flat end of the spudger.
  14. Dell XPS 13 Display Assembly Replacement: 14 단계, 이미지 1/3 Dell XPS 13 Display Assembly Replacement: 14 단계, 이미지 2/3 Dell XPS 13 Display Assembly Replacement: 14 단계, 이미지 3/3
    • Using a spudger, pry up the press fit connector on the end of the left cable bundle.
    • Gently remove the sliding cable connector from its port to the left of the fan.
  15. Dell XPS 13 Display Assembly Replacement: 15 단계, 이미지 1/3 Dell XPS 13 Display Assembly Replacement: 15 단계, 이미지 2/3 Dell XPS 13 Display Assembly Replacement: 15 단계, 이미지 3/3
    • Remove the four, black 4.6 mm screws from the display mounts using a Phillips #0 screwdriver.
    • The laptop needs to be open for the display to clear the cutouts of the bottom case, so you may find it easier to remove the screws while already in an open configuration.
    • Remove the display assembly.
결론
다른 10명이 해당 안내서를 완성하였습니다.
Austin Blakely
회원 가입일: 03/11/19
19,506 평판
안내서 53개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,817개 작성하였습니다
댓글 2개
After disassembling the screen, how do I peel it off the metal screen cover?
Jon - 답글
I need to find out what screen model I have to buy a display controller to re-use the screen on a different project, but I’m not able to see behind the screen to find out the exact model.
Jon - 답글
댓글 쓰기
조회 통계:
24 시간 전: 15
7일 전: 94
30일 전: 383
전체 시간: 27,667
