주요 콘텐츠로 건너뛰기
Dell XPS 13 Fan Replacement
필요한 것
  1. Dell XPS 13 Fan Replacement, Back Cover: 1 단계, 이미지 1/2 Dell XPS 13 Fan Replacement, Back Cover: 1 단계, 이미지 2/2
    • Remove the eight 4 mm T5 Torx screws from the bottom cover.
  2. Dell XPS 13 Fan Replacement: 2 단계, 이미지 1/2 Dell XPS 13 Fan Replacement: 2 단계, 이미지 2/2
    • Use a plastic opening tool to pry open the 'XPS' flap in the middle.
  3. Dell XPS 13 Fan Replacement: 3 단계, 이미지 1/1
    • Remove the single Phillips screw hidden beneath the flap.
  4. Dell XPS 13 Fan Replacement: 4 단계, 이미지 1/1
    • Use opening picks or a plastic pry tool to pry open the case clips, beginning from the back edge.
  5. Dell XPS 13 Fan Replacement: 5 단계, 이미지 1/1
    • Remove the bottom cover.
  6. Dell XPS 13 Fan Replacement, Battery Disconnection: 6 단계, 이미지 1/2 Dell XPS 13 Fan Replacement, Battery Disconnection: 6 단계, 이미지 2/2
    • Pull the battery cable connector towards the battery to disconnect it from its socket.
    • If the connector is stubborn, push a little at one side, then the other, to "walk" it out of its socket.
    • If you have trouble walking the connector out of the socket, use the point of a spudger to gently push on the connector indent to slide the connector out.
    • Do not pull up.
    • Open the display and press the power button for five seconds to drain any remaining charge from the system.
  7. Dell XPS 13 Fan Replacement, Fan: 7 단계, 이미지 1/3 Dell XPS 13 Fan Replacement, Fan: 7 단계, 이미지 2/3 Dell XPS 13 Fan Replacement, Fan: 7 단계, 이미지 3/3
    • Use tweezers to remove the little white connector by pulling it out and away from its socket.
  8. Dell XPS 13 Fan Replacement: 8 단계, 이미지 1/2 Dell XPS 13 Fan Replacement: 8 단계, 이미지 2/2
    • Remove the black standard flat connector by lifting the tab up with your hand.
  9. Dell XPS 13 Fan Replacement: 9 단계, 이미지 1/2 Dell XPS 13 Fan Replacement: 9 단계, 이미지 2/2
    • Remove the 4 mm Phillips #0 screw that connects the fan to the motherboard.
    • Remove the 4 mm Phillips #0 screw that connects the fan to the base of the computer.
  10. Dell XPS 13 Fan Replacement: 10 단계, 이미지 1/2 Dell XPS 13 Fan Replacement: 10 단계, 이미지 2/2
    • Use your right hand to lift up the larger section of the motherboard, closest to the fan.
    • Use your left hand to pull the fan at a 30-degree angle out from underneath the motherboard.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Ella Herrmann
회원 가입일: 04/24/17
1,588 평판
안내서 3개 작성하였습니다
Cal Poly, Team S21-G6, Livingston Spring 2017 Cal Poly, Team S21-G6, Livingston Spring 2017 회원
CPSU-LIVINGSTON-S17S21G6
5 회원들
안내서 30개 작성하였습니다
댓글 3개
Great guide! The two hardest parts were getting the back cover off, and lifting the motherboard to remove the fan. Took me about 30 minutes in total.
John Reeder - 답글
It would be really easier if you remove the battery screws first… there are some steps that were not clear…
Nicolás Jiménez Bautista - 답글
This repair took me about 45 min for a complete novice. “Walking out” the battery connector was only way I could unplug it. There was a retaining bracket overlaying the flat connector (step 8) that I needed to unscrew (2 screws, phillips) before it could be removed. Take care to replace the wire in the wire guides along the fan’s housing prior to reinsertion of the replacement fan. It cannot be done afterwards and the back panel will not be flush. Otherwise, this was an excellent guide and an easy repair.
Scott Freeman - 답글
댓글 쓰기
조회 통계:
24 시간 전: 11
7일 전: 57
30일 전: 263
전체 시간: 21,894
