주요 콘텐츠로 건너뛰기
Dell XPS 13 9360 SSD Replacement
필요한 것
  1. Dell XPS 13 9360 SSD Replacement, SSD (Solid State Drive): 1 단계, 이미지 1개 중 1개
    • Power off your laptop and unplug it from the charger.
  2. Dell XPS 13 9360 SSD Replacement: 2 단계, 이미지 2개 중 1개 Dell XPS 13 9360 SSD Replacement: 2 단계, 이미지 2개 중 2개
    • Close the laptop lid and place it so the bottom side faces up.
  3. Dell XPS 13 9360 SSD Replacement: 3 단계, 이미지 3개 중 1개 Dell XPS 13 9360 SSD Replacement: 3 단계, 이미지 3개 중 2개 Dell XPS 13 9360 SSD Replacement: 3 단계, 이미지 3개 중 3개
    • Use a Torx T5 screwdriver to remove eight 3 mm screws around the edge of the back cover.
  4. Dell XPS 13 9360 SSD Replacement: 4 단계, 이미지 3개 중 1개 Dell XPS 13 9360 SSD Replacement: 4 단계, 이미지 3개 중 2개 Dell XPS 13 9360 SSD Replacement: 4 단계, 이미지 3개 중 3개
    • Lift the small magnetic flap cover in the center of the back case.
    • Use a JIS J0 screwdriver to remove the 6 mm screw under the flap cover.
  5. Dell XPS 13 9360 SSD Replacement: 5 단계, 이미지 3개 중 1개 Dell XPS 13 9360 SSD Replacement: 5 단계, 이미지 3개 중 2개 Dell XPS 13 9360 SSD Replacement: 5 단계, 이미지 3개 중 3개
    • Wedge the guitar pick between the cover and the base of the laptop.
    • Start at the front edge of the base cover and continue around the perimeter of the laptop, carefully prying up the base cover.
    • Pull off the base cover.
    • As you use the guitar pick to work around the base cover, it will gradually loosen. You can then gently pull it off completely.
  6. Dell XPS 13 9360 SSD Replacement: 6 단계, 이미지 3개 중 1개 Dell XPS 13 9360 SSD Replacement: 6 단계, 이미지 3개 중 2개 Dell XPS 13 9360 SSD Replacement: 6 단계, 이미지 3개 중 3개
    • Disconnect the battery before removing the SSD.
    • Use the JIS J0 screwdriver to remove the single 2 mm screw securing the existing SSD.
    • The SSD will automatically "pop up".
    • Gently slide it out from the socket.
  7. Dell XPS 13 9360 SSD Replacement: 7 단계, 이미지 2개 중 1개 Dell XPS 13 9360 SSD Replacement: 7 단계, 이미지 2개 중 2개
    • Slide the new SSD into the slot at the same angle used when removing the old one.
    • Make sure to align the notches on the SSD correctly with the tab openings of the slot to avoid damaging the SSD and the PCIe slot.
    • Press down on the SSD gently to hold it down.
  8. Dell XPS 13 9360 SSD Replacement: 8 단계, 이미지 3개 중 1개 Dell XPS 13 9360 SSD Replacement: 8 단계, 이미지 3개 중 2개 Dell XPS 13 9360 SSD Replacement: 8 단계, 이미지 3개 중 3개
    • Follow the remaining instructions in reverse order to reassemble.
    • Make sure that when you replace the back cover you press down along the edges to ensure that it snaps back into place.
  9. Dell XPS 13 9360 SSD Replacement: 9 단계, 이미지 2개 중 1개 Dell XPS 13 9360 SSD Replacement: 9 단계, 이미지 2개 중 2개
    • Now you can power on the laptop again and use it!
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Diana Ramirez-S.
회원 가입일: 03/03/24
317 평판
안내서 1개를 작성함
1가이드 댓글
Simple instructions. Could have used a little more detail in step 6 on how to disconnect the battery cable.
Rich Stillman - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 19
지난 30일: 74
전체 시간: 1,174
