주요 콘텐츠로 건너뛰기
Dell XPS 13 9365 2-in-1 Display Assembly Replacement
필요한 것
  1. Dell XPS 13 9365 2-in-1 Display Assembly Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Use a Torx T4 screwdriver to remove the eight screws (M2x3) that secure the base cover to the palm-rest assembly.
  2. Dell XPS 13 9365 2-in-1 Display Assembly Replacement: 2 단계, 이미지 1개 중 1개
    • Use your fingertips to lift the system badge open and reveal the single case screw.
    • Use a Phillips #000 screwdriver to remove the screw (M1.6x4) that secures the base cover to the palm-rest assembly.
  3. Dell XPS 13 9365 2-in-1 Display Assembly Replacement: 3 단계, 이미지 1개 중 1개
    • Starting from the front corner of the computer, pry up the base cover using a spudger and lift the base cover off the palm-rest assembly.
  4. Dell XPS 13 9365 2-in-1 Display Assembly Replacement: 4 단계, 이미지 1개 중 1개
    • Disconnect the battery cable from the system board.
  5. Dell XPS 13 9365 2-in-1 Display Assembly Replacement: 5 단계, 이미지 1개 중 1개
    • Use a Phillips #000 screwdriver to remove the two screws (M1.6x4) that secure the battery to the palm-rest assembly.
  6. Dell XPS 13 9365 2-in-1 Display Assembly Replacement: 6 단계, 이미지 1개 중 1개
    • Use a Phillips #000 screwdriver to remove the six screws (M2x3) that secure the battery to the palm-rest assembly.
  7. Dell XPS 13 9365 2-in-1 Display Assembly Replacement: 7 단계, 이미지 1개 중 1개
    • Lift the battery off the palm-rest assembly.
  8. Dell XPS 13 9365 2-in-1 Display Assembly Replacement, Display Assembly: 8 단계, 이미지 1개 중 1개
    • Use a Phillips #000 screwdriver to remove the screw (M1.6x2.5) that secures the wireless-card bracket to the motherboard.
  9. Dell XPS 13 9365 2-in-1 Display Assembly Replacement: 9 단계, 이미지 1개 중 1개
    • Lift the wireless-card bracket off the wireless card.
  10. Dell XPS 13 9365 2-in-1 Display Assembly Replacement: 10 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Use a pair of nylon tipped tweezers to gently disconnect the antenna cables from the wireless card.
  11. Dell XPS 13 9365 2-in-1 Display Assembly Replacement: 11 단계, 이미지 1개 중 1개
    • Peel off the tape that secures the display cable to the M.2 solid-state drive heatsink.
  12. Dell XPS 13 9365 2-in-1 Display Assembly Replacement: 12 단계, 이미지 2개 중 1개 Dell XPS 13 9365 2-in-1 Display Assembly Replacement: 12 단계, 이미지 2개 중 2개
    • Use a Phillips #000 screwdriver to remove the two screws (M1.6x2.5) that secure the display cable bracket to the motherboard.
    • Lift the display cable bracket off the display cable.
  13. Dell XPS 13 9365 2-in-1 Display Assembly Replacement: 13 단계, 이미지 1개 중 1개
    • Use the pull tab to disconnect the display cable from the motherboard.
  14. Dell XPS 13 9365 2-in-1 Display Assembly Replacement: 14 단계, 이미지 1개 중 1개
    • Disconnect the touch-screen cable from the system board (labeled "TS").
  15. Dell XPS 13 9365 2-in-1 Display Assembly Replacement: 15 단계, 이미지 1개 중 1개
    • Disconnect the camera cable from the system board.
  16. Dell XPS 13 9365 2-in-1 Display Assembly Replacement: 16 단계, 이미지 3개 중 1개 Dell XPS 13 9365 2-in-1 Display Assembly Replacement: 16 단계, 이미지 3개 중 2개 Dell XPS 13 9365 2-in-1 Display Assembly Replacement: 16 단계, 이미지 3개 중 3개
    • Open the palm-rest assembly fully and place the display assembly and palm-rest assembly face down.
    • Make sure that your surface is flat and free of objects when you lay the laptop face down.
    • Use a Phillips #000 screwdriver to remove the six screws (M2.5x3.5) that secure the display hinges to the palm-rest assembly. There are three on each side.
  17. Dell XPS 13 9365 2-in-1 Display Assembly Replacement: 17 단계, 이미지 1개 중 1개
    • Lift the display assembly off the palm-rest assembly.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Melissa Schlein
회원 가입일: 03/21/22
731 평판
안내서 3개를 작성함
1가이드 댓글
how to disassembly hinge for replace the video cable?
Logan Solo - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 10
지난 30일: 34
전체 시간: 1,252
