주요 콘텐츠로 건너뛰기
Dell XPS 13 9365 2-in-1 Speakers Replacement
필요한 것
  1. Dell XPS 13 9365 2-in-1 Speakers Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Use a Torx T4 screwdriver to remove the eight screws (M2x3) that secure the base cover to the palm-rest assembly.
  2. Dell XPS 13 9365 2-in-1 Speakers Replacement: 2 단계, 이미지 1개 중 1개
    • Use your fingertips to lift the system badge open and reveal the single case screw.
    • Use a Phillips #000 screwdriver to remove the screw (M1.6x4) that secures the base cover to the palm-rest assembly.
  3. Dell XPS 13 9365 2-in-1 Speakers Replacement: 3 단계, 이미지 1개 중 1개
    • Starting from the front corner of the computer, pry up the base cover using a spudger and lift the base cover off the palm-rest assembly.
  4. Dell XPS 13 9365 2-in-1 Speakers Replacement: 4 단계, 이미지 1개 중 1개
    • Disconnect the battery cable from the system board.
  5. Dell XPS 13 9365 2-in-1 Speakers Replacement: 5 단계, 이미지 1개 중 1개
    • Use a Phillips #000 screwdriver to remove the two screws (M1.6x4) that secure the battery to the palm-rest assembly.
  6. Dell XPS 13 9365 2-in-1 Speakers Replacement: 6 단계, 이미지 1개 중 1개
    • Use a Phillips #000 screwdriver to remove the six screws (M2x3) that secure the battery to the palm-rest assembly.
  7. Dell XPS 13 9365 2-in-1 Speakers Replacement: 7 단계, 이미지 1개 중 1개
    • Lift the battery off the palm-rest assembly.
  8. Dell XPS 13 9365 2-in-1 Speakers Replacement, Speakers: 8 단계, 이미지 1개 중 1개
    • Peel off the tape securing the speaker cable to the system board.
  9. Dell XPS 13 9365 2-in-1 Speakers Replacement: 9 단계, 이미지 1개 중 1개
    • Disconnect the speaker cable from the motherboard.
  10. Dell XPS 13 9365 2-in-1 Speakers Replacement: 10 단계, 이미지 1개 중 1개
    • Note the speaker-cable routing and peel off the tape that secures the speaker cable to the system board.
  11. Dell XPS 13 9365 2-in-1 Speakers Replacement: 11 단계, 이미지 2개 중 1개 Dell XPS 13 9365 2-in-1 Speakers Replacement: 11 단계, 이미지 2개 중 2개
    • Use a Phillips #000 screwdriver to remove the four screws (M2x2) that secure the speakers to the palm-rest assembly.
  12. Dell XPS 13 9365 2-in-1 Speakers Replacement: 12 단계, 이미지 1개 중 1개
    • Lift the speakers, along with its cables, off the palm-rest assembly.
결론
작성자
1다른 기여자 명과 함께
Melissa Schlein
회원 가입일: 03/21/22
716 평판
안내서 3개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 16
전체 시간: 543
