주요 콘텐츠로 건너뛰기
Dell XPS 13 9370 Battery Replacement
필요한 것
    • Save and close all open files and exit all open applications.
    • Shut down your computer. Click Start > Power > Shut down.
    • Disconnect your computer and all attached devices from their electrical outlets.
    • Disconnect all attached network devices and peripherals, such as keyboard, mouse, and monitor from your computer.
    • Remove any media card and optical disc from your computer, if applicable.
  1. Dell XPS 13 9370 Battery Replacement, Remove the base cover screws: 2 단계, 이미지 1/1
    • Remove the eight screws (M2x3, Torx) that secure the base cover to the palm-rest assembly.
  2. Dell XPS 13 9370 Battery Replacement, Remove the base cover: 3 단계, 이미지 1/2 Dell XPS 13 9370 Battery Replacement, Remove the base cover: 3 단계, 이미지 2/2
    • With the computer face-down, open the computer at an angle.
    • Using a plastic scribe (spudger), pry the base cover from the palm-rest assembly.
    • Moving the base cover from left to right, release the clips securing the base cover to the palm-rest assembly.
    • Lift the base cover from the palm-rest assembly.
  3. Dell XPS 13 9370 Battery Replacement, Disconnect battery cable: 4 단계, 이미지 1/1
    • Disconnect the battery cable from the system board.
  4. Dell XPS 13 9370 Battery Replacement, Remove the battery: 5 단계, 이미지 1/1
    • Remove the four screws (M2x2) that secure the battery to the palm-rest assembly.
    • Remove the screw (M1.6x4) that secures the battery to the palm-rest assembly.
    • Lift the battery off the palm-rest assembly.
    • Turn the computer over, open the display, and press the power button for about 5 seconds to ground the computer.
결론
To replace the battery & reassemble your device, follow these instructions in reverse order.
다른 23명이 해당 안내서를 완성하였습니다.
Max Kletskov
회원 가입일: 04/22/20
40,418 평판
안내서 16개 작성하였습니다
iFixit iFixit 회원
Staff
140 회원들
안내서 18,085개 작성하였습니다
댓글 8개
Is the battery an original dell battery?
mnyousafva - 답글
Why doesn’t it say what tools are needed?
Noah Guirguis - 답글
Excellent guide. Took me about 25 minutes. Works perfectly.
Jeff Doremus - 답글
Instructions were perfect, thanks for the great guide!
surfdaworld - 답글
Boom, in a good way! I fixed it!
Chris Cox - 답글
댓글 쓰기
조회 통계:
24 시간 전: 11
7일 전: 84
30일 전: 399
전체 시간: 16,465
