주요 콘텐츠로 건너뛰기
Dell XPS 13 L321X Battery Replacement
필요한 것
  1. Dell XPS 13 L321X Battery Replacement, Battery: 1 단계, 이미지 1/2 Dell XPS 13 L321X Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Remove ten 3mm screws from the back cover with a T5 screwdriver.
  2. Dell XPS 13 L321X Battery Replacement: 2 단계, 이미지 1/2 Dell XPS 13 L321X Battery Replacement: 2 단계, 이미지 2/2
    • Disconnect the ribbon cable with a plastic iFixit opening tool by lifting up the black clip and pulling the white ribbon off.
    • Pull aside the ribbon cable.
  3. Dell XPS 13 L321X Battery Replacement: 3 단계, 이미지 1/1
    • Insert a plastic iFixit opening tool in between the port and the wires to remove the battery cable.
  4. Dell XPS 13 L321X Battery Replacement: 4 단계, 이미지 1/2 Dell XPS 13 L321X Battery Replacement: 4 단계, 이미지 2/2
    • Take out 8 silver screws that are holding the battery with a PH00 head screwdriver.
    • Six 3mm screws.
    • Two 5mm screws.
    • Lift the battery out.
결승점
다른 6명이 해당 안내서를 완성하였습니다.
Ahmad EL Herbawi
회원 가입일: 03/01/17
499 평판
안내서 3개 작성하였습니다
USF Tampa, Team S6-G3, Lacy Spring 2017 USF Tampa, Team S6-G3, Lacy Spring 2017 회원
USFT-LACY-S17S6G3
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 7
전체 시간: 2,629
