소개
In order to get to the main source(s) of your computer, which is most likely inside of your computer, these are the necessary steps you can follow to remove the bottom cover.
필요한 것
Use a Torx T5 screwdriver to remove the 10 screws from the computer's base plate.
Use a prying tool or a fingernail to lift up and remove the base cover.
거의 끝나갑니다!
결론
