주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
보관됨
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
보관됨
소개
Use this guide to replace the motherboard in the Dell XPS 13.
  1. Remove the eight 4 mm T5 Torx screws from the bottom cover. Remove the eight 4 mm T5 Torx screws from the bottom cover.
    • Remove the eight 4 mm T5 Torx screws from the bottom cover.
  2. Use a plastic opening tool to pry open the 'XPS' flap in the middle. Use a plastic opening tool to pry open the 'XPS' flap in the middle.
    • Use a plastic opening tool to pry open the 'XPS' flap in the middle.
  3. Remove the single Phillips screw hidden beneath the flap.
    • Remove the single Phillips screw hidden beneath the flap.
  4. Use opening picks or a plastic pry tool to pry open the case clips, beginning from the back edge.
    • Use opening picks or a plastic pry tool to pry open the case clips, beginning from the back edge.
  5. Remove the bottom cover.
    • Remove the bottom cover.
  6. Pull the battery cable connector towards the battery to disconnect it from its socket. If the connector is stubborn, push a little at one side, then the other, to "walk" it out of its socket.
    • Pull the battery cable connector towards the battery to disconnect it from its socket.
    • If the connector is stubborn, push a little at one side, then the other, to "walk" it out of its socket.
    • If you have trouble walking the connector out of the socket, use the point of a spudger to gently push on the connector indent to slide the connector out.
    • Do not pull up.
    • Open the display and press the power button for five seconds to drain any remaining charge from the system.
  7. Use tweezers to remove the little white connector by pulling it out and away from its socket. Use tweezers to remove the little white connector by pulling it out and away from its socket. Use tweezers to remove the little white connector by pulling it out and away from its socket.
    • Use tweezers to remove the little white connector by pulling it out and away from its socket.
  8. Remove the black standard flat connector by lifting the tab up with your hand. Remove the black standard flat connector by lifting the tab up with your hand.
    • Remove the black standard flat connector by lifting the tab up with your hand.
  9. Remove the 4 mm Phillips #0 screw that connects the fan to the motherboard. Remove the 4 mm Phillips #0 screw that connects the fan to the base of the computer.
    • Remove the 4 mm Phillips #0 screw that connects the fan to the motherboard.
    • Remove the 4 mm Phillips #0 screw that connects the fan to the base of the computer.
  10. Use your right hand to lift up the larger section of the motherboard, closest to the fan. Use your left hand to pull the fan at a 30-degree angle out from underneath the motherboard.
    • Use your right hand to lift up the larger section of the motherboard, closest to the fan.
    • Use your left hand to pull the fan at a 30-degree angle out from underneath the motherboard.
  11. Remove the four 3 mm Phillips #0 screws located on each corner of the battery. Remove the four 3 mm Phillips #0 screws located on each corner of the battery.
    • Remove the four 3 mm Phillips #0 screws located on each corner of the battery.
  12. Pull the battery cable connector towards the battery to disconnect it from its socket. Do not pull up.
    • Do not pull up.
  13. Peel up any tape securing the speaker cables to the battery.
    • Peel up any tape securing the speaker cables to the battery.
    • You do not need to remove the speakers, only the tape, allowing the battery to be removed out under the speaker cables.
  14. Remove the battery.
    • Remove the battery.
  15. Remove the eight 4 mm Phillips #0 screws from the motherboard. Remove the eight 4 mm Phillips #0 screws from the motherboard.
    • Remove the eight 4 mm Phillips #0 screws from the motherboard.
  16. Locate the red and black cable connector at the bottom right of the motherboard. Use tweezers to slowly detach the cable connector from its socket by pulling it to the right and up. Use tweezers to slowly detach the cable connector from its socket by pulling it to the right and up.
    • Locate the red and black cable connector at the bottom right of the motherboard.
    • Use tweezers to slowly detach the cable connector from its socket by pulling it to the right and up.
  17. Use tweezers to flip open the Zero Insertion Force (ZIF) connector. Use tweezers to detach the ribbon cable from the ZIF by pulling it towards yourself. Use tweezers to detach the ribbon cable from the ZIF by pulling it towards yourself.
    • Use tweezers to flip open the Zero Insertion Force (ZIF) connector.
    • Use tweezers to detach the ribbon cable from the ZIF by pulling it towards yourself.
  18. Use tweezers to flip open the white ZIF connector. Use tweezers to detach the ribbon connector from the ZIF by pulling it towards yourself. Use tweezers to detach the ribbon connector from the ZIF by pulling it towards yourself.
    • Use tweezers to flip open the white ZIF connector.
    • Use tweezers to detach the ribbon connector from the ZIF by pulling it towards yourself.
  19. Use tweezers to flip open the ZIF connector. Use tweezers to detach the orange ribbon connector from the ZIF by pulling it towards yourself. Use tweezers to detach the orange ribbon connector from the ZIF by pulling it towards yourself.
    • Use tweezers to flip open the ZIF connector.
    • Use tweezers to detach the orange ribbon connector from the ZIF by pulling it towards yourself.
  20. Use tweezers to detach the black cable connector out of its socket by pulling it to the right. Use tweezers to detach the black cable connector out of its socket by pulling it to the right.
    • Use tweezers to detach the black cable connector out of its socket by pulling it to the right.
  21. Use tweezers to gently detach the black and white cable connector out of its socket by pulling it to the right. Use tweezers to gently detach the black and white cable connector out of its socket by pulling it to the right. Use tweezers to gently detach the black and white cable connector out of its socket by pulling it to the right.
    • Use tweezers to gently detach the black and white cable connector out of its socket by pulling it to the right.
  22. Locate the connector at the top right of the motherboard. Use tweezers to detach the cable connector from its socket by pulling it to the right.
    • Locate the connector at the top right of the motherboard.
    • Use tweezers to detach the cable connector from its socket by pulling it to the right.
  23. Locate the last black cable connector. Use tweezers to detach the black cable connector from its socket by pulling it to the right. Use tweezers to detach the black cable connector from its socket by pulling it to the right.
    • Locate the last black cable connector.
    • Use tweezers to detach the black cable connector from its socket by pulling it to the right.
  24. Use your hands to lift up the motherboard.
    • Use your hands to lift up the motherboard.
결론
다른 11명이 해당 안내서를 완성하였습니다.
Evan Shui
회원 가입일: 2017년 04월 26일
302 평판
안내서 1개 작성함
Cal Poly, Team S21-G6, Livingston Spring 2017 Cal Poly, Team S21-G6, Livingston Spring 2017 회원
CPSU-LIVINGSTON-S17S21G6
5 회원들
안내서 24개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 10
7일 전: 51
30일 전: 287
전체 시간: 11,623
