주요 콘텐츠로 건너뛰기
Dell XPS 13 Track Pad Replacement
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
필요한 것
  1. Dell XPS 13 Track Pad Replacement, Back Cover: 1 단계, 이미지 1/2 Dell XPS 13 Track Pad Replacement, Back Cover: 1 단계, 이미지 2/2
    • Remove the eight 4 mm T5 Torx screws from the bottom cover.
  2. Dell XPS 13 Track Pad Replacement: 2 단계, 이미지 1/2 Dell XPS 13 Track Pad Replacement: 2 단계, 이미지 2/2
    • Use a plastic opening tool to pry open the 'XPS' flap in the middle.
  3. Dell XPS 13 Track Pad Replacement: 3 단계, 이미지 1/1
    • Remove the single Phillips screw hidden beneath the flap.
  4. Dell XPS 13 Track Pad Replacement: 4 단계, 이미지 1/1
    • Use opening picks or a plastic pry tool to pry open the case clips, beginning from the back edge.
  5. Dell XPS 13 Track Pad Replacement: 5 단계, 이미지 1/1
    • Remove the bottom cover.
  6. Dell XPS 13 Track Pad Replacement, Battery Disconnection: 6 단계, 이미지 1/2 Dell XPS 13 Track Pad Replacement, Battery Disconnection: 6 단계, 이미지 2/2
    • Pull the battery cable connector towards the battery to disconnect it from its socket.
    • If the connector is stubborn, push a little at one side, then the other, to "walk" it out of its socket.
    • If you have trouble walking the connector out of the socket, use the point of a spudger to gently push on the connector indent to slide the connector out.
    • Do not pull up.
    • Open the display and press the power button for five seconds to drain any remaining charge from the system.
  7. Dell XPS 13 Track Pad Replacement, Battery: 7 단계, 이미지 1/2 Dell XPS 13 Track Pad Replacement, Battery: 7 단계, 이미지 2/2
    • Remove the four 3 mm Phillips #0 screws located on each corner of the battery.
  8. Dell XPS 13 Track Pad Replacement: 8 단계, 이미지 1/2 Dell XPS 13 Track Pad Replacement: 8 단계, 이미지 2/2
    • Do not pull up.
  9. Dell XPS 13 Track Pad Replacement: 9 단계, 이미지 1/1
    • Peel up any tape securing the speaker cables to the battery.
    • You do not need to remove the speakers, only the tape, allowing the battery to be removed out under the speaker cables.
  10. Dell XPS 13 Track Pad Replacement: 10 단계, 이미지 1/1
    • Remove the battery.
  11. Dell XPS 13 Track Pad Replacement, Track Pad: 11 단계, 이미지 1/2 Dell XPS 13 Track Pad Replacement, Track Pad: 11 단계, 이미지 2/2
    • Remove the four 3 mm Phillips #1 screws from the trackpad.
  12. Dell XPS 13 Track Pad Replacement: 12 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Use tweezers to gently lift the upper-right corner of the track pad.
    • Remove the track pad by slowly pulling it up and away from you.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Arvind Krish
회원 가입일: 04/26/17
179 평판
안내서 1개 작성함
Cal Poly, Team S21-G6, Livingston Spring 2017 Cal Poly, Team S21-G6, Livingston Spring 2017 회원
CPSU-LIVINGSTON-S17S21G6
5 회원들
안내서 30개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 8
7일 전: 41
30일 전: 154
전체 시간: 13,366
