소개
How to replace the wireless card in your XPS 13. If you’re having trouble connecting to wi-fi, replacing or re-seating the wireless card may fix it.
필요한 것
Pull the battery cable connector towards the battery to disconnect it from its socket.
If the connector is stubborn, push a little at one side, then the other, to "walk" it out of its socket.
If you have trouble walking the connector out of the socket, use the point of a spudger to gently push on the connector indent to slide the connector out.
Open the display and press the power button for five seconds to drain any remaining charge from the system.
Pry the white and black antenna wire connectors straight up from the wireless card to disconnect them.
To reconnect each wire, align the connector carefully over its socket and press down firmly.
다른 16명이 해당 안내서를 완성하였습니다.
댓글 한 개
Thanks for the instructions on swapping out the WiFi module/chip, it looked pretty straightforward from what I could tell when I had the machine open, I just have a simple question for you.
I recently purchased an Intel Dual Band Wireless -AC 8265 Desktop Kit and I do NOT plan on using the external antenna, or mounting bracket that came with it, ONLY the chip in place of the one on the laptop.
So I wanted to know would the chip in that kit be useable in my Dell XPS 13 9343 model laptop? Everything looks to be about the same with this chip and the actual laptop model [except that the laptop one doesn’t come with the external antenna], so if I can use it that would save me shipping it back and then ordering again.
Thanks
