주요 콘텐츠로 건너뛰기
Dell XPS 1340 CPU Fan Replacement
필요한 것
  1. Dell XPS 1340 CPU Fan Replacement, CPU Fan: 1 단계, 이미지 1/1
    • Remove the battery by sliding the battery lock switch
  2. Dell XPS 1340 CPU Fan Replacement: 2 단계, 이미지 1/1
    • Remove the lower panel of the laptop by loosening 10 screws. Note that the screws do no come out of the back panel.
  3. Dell XPS 1340 CPU Fan Replacement: 3 단계, 이미지 1/1
    • Remove two screws which holds a smaller back panel covering only the heatsink
  4. Dell XPS 1340 CPU Fan Replacement: 4 단계, 이미지 1/2 Dell XPS 1340 CPU Fan Replacement: 4 단계, 이미지 2/2
    • Loosen the four screws on the heat sink for the CPU. Note that these screws don't come out.
    • Now carefully lift the unit from holding the heat pipe.
    • After the heat-pipe unit is removed, the power connector for the fan is accessible.
  5. Dell XPS 1340 CPU Fan Replacement: 5 단계, 이미지 1/2 Dell XPS 1340 CPU Fan Replacement: 5 단계, 이미지 2/2
    • First remove the power connector for the CPU Fan.
    • Now remove the two screws connecting the CPU Fan.
    • Slowly slide the CPU Fan upwards. It would be a little tight around the edges.
  6. Dell XPS 1340 CPU Fan Replacement: 6 단계, 이미지 1/1
    • Unpack the new fan. Make sure the power wires are fixed in the hook provided.
    • Follow all step backwards and finish.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Paras Tolani
회원 가입일: 03/01/13
188 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 2,790
