주요 콘텐츠로 건너뛰기
Dell XPS 14 L401X Keyboard Replacement
필요한 것
  1. Dell XPS 14 L401X Keyboard Replacement, Battery: 1 단계, 이미지 1/2 Dell XPS 14 L401X Keyboard Replacement, Battery: 1 단계, 이미지 2/2
    • Make sure that the laptop is shut off before attempting to remove any components from the device.
    • The laptop in this example did not have a battery equipped.
    • Locate the spring latch on the bottom of the device that will unlatch the battery.
    • Hold the spring latch in the open position and pull the battery out of its recess.
  2. Dell XPS 14 L401X Keyboard Replacement, RAM: 2 단계, 이미지 1/3 Dell XPS 14 L401X Keyboard Replacement, RAM: 2 단계, 이미지 2/3 Dell XPS 14 L401X Keyboard Replacement, RAM: 2 단계, 이미지 3/3
    • Use a JIS 1 screwdriver to loosen the (2) captive screws from the panel.
    • The captive screws will not come off of the panel.
    • Pull the panel upwards and towards the battery to remove.
    • Put the panel to the side, exposing the RAM.
  3. Dell XPS 14 L401X Keyboard Replacement: 3 단계, 이미지 1/2 Dell XPS 14 L401X Keyboard Replacement: 3 단계, 이미지 2/2
    • The RAM is held by two spring clips. Pull at the two spring clips and the RAM will move upwards.
    • Keep your fingers on the edge of the chip.
    • Only handle the RAM by the sides! Do not touch the circuits or the terminals to avoid contamination!
  4. Dell XPS 14 L401X Keyboard Replacement, Optical Drive: 4 단계, 이미지 1/2 Dell XPS 14 L401X Keyboard Replacement, Optical Drive: 4 단계, 이미지 2/2
    • Locate and remove (1) 8.5mm JIS 1 screw at the top left corner of the RAM bay.
  5. Dell XPS 14 L401X Keyboard Replacement: 5 단계, 이미지 1/3 Dell XPS 14 L401X Keyboard Replacement: 5 단계, 이미지 2/3 Dell XPS 14 L401X Keyboard Replacement: 5 단계, 이미지 3/3
    • Carefully pull out the optical drive from its bay.
  6. Dell XPS 14 L401X Keyboard Replacement: 6 단계, 이미지 1/2 Dell XPS 14 L401X Keyboard Replacement: 6 단계, 이미지 2/2
    • Carefully pull off the decorative cover from the front of the optical drive.
    • This decorative cover will be transferred to the new optical drive.
  7. Dell XPS 14 L401X Keyboard Replacement: 7 단계, 이미지 1/3 Dell XPS 14 L401X Keyboard Replacement: 7 단계, 이미지 2/3 Dell XPS 14 L401X Keyboard Replacement: 7 단계, 이미지 3/3
    • Use a JIS 1 screwdriver to remove (2) 2mm screws on the drive's anchoring bracket.
    • This bracket will be transferred to the new optical drive.
  8. Dell XPS 14 L401X Keyboard Replacement, Hard Drive: 8 단계, 이미지 1/2 Dell XPS 14 L401X Keyboard Replacement, Hard Drive: 8 단계, 이미지 2/2
    • Use a JIS 1 screwdriver to remove (2) 2.5mm screws located on the right side of the RAM bay.
  9. Dell XPS 14 L401X Keyboard Replacement: 9 단계, 이미지 1/2 Dell XPS 14 L401X Keyboard Replacement: 9 단계, 이미지 2/2
    • Push the hard drive to the right with a spudger to unseat it from its socket while pulling out the hard drive with your other hand.
  10. Dell XPS 14 L401X Keyboard Replacement: 10 단계, 이미지 1/3 Dell XPS 14 L401X Keyboard Replacement: 10 단계, 이미지 2/3 Dell XPS 14 L401X Keyboard Replacement: 10 단계, 이미지 3/3
    • Use a JIS 1 screwdriver to remove (1) 2.5mm screw attaching the plastic cosmetic cover to the hard drive.
    • Detach the plastic cosmetic cover from the hard drive.
    • This cosmetic cover will be transferred to the new hard drive.
  11. Dell XPS 14 L401X Keyboard Replacement, Mini Card: 11 단계, 이미지 1/3 Dell XPS 14 L401X Keyboard Replacement, Mini Card: 11 단계, 이미지 2/3 Dell XPS 14 L401X Keyboard Replacement, Mini Card: 11 단계, 이미지 3/3
    • Locate the mini card access panel marked with a radio tower emblem on the bottom of the laptop near the battery bay.
    • Use a JIS 1 screwdriver to loosen the captive screw securing the panel to the device.
    • The captive screw will not come off of the panel.
    • Carefully remove the panel by prying it upwards, unlocking it from the tabs that are securing it in place.
  12. Dell XPS 14 L401X Keyboard Replacement: 12 단계, 이미지 1/3 Dell XPS 14 L401X Keyboard Replacement: 12 단계, 이미지 2/3 Dell XPS 14 L401X Keyboard Replacement: 12 단계, 이미지 3/3
    • Disconnect the two wires on the mini card by carefully plucking them upwards by the metal contact points at the terminals.
    • Do not pluck the contacts off of the terminals by pulling on the wires, this can damage the cables.
    • Remove (1) 2mm screw from the bottom left corner of the mini card with a JIS 1 screwdriver.
  13. Dell XPS 14 L401X Keyboard Replacement: 13 단계, 이미지 1/2 Dell XPS 14 L401X Keyboard Replacement: 13 단계, 이미지 2/2
    • Remove the mini card as it flips upward.
  14. Dell XPS 14 L401X Keyboard Replacement, Palm Rest: 14 단계, 이미지 1/2 Dell XPS 14 L401X Keyboard Replacement, Palm Rest: 14 단계, 이미지 2/2
    • Remove two 4.5mm screws with JIS 1 screwdriver marked by the letter "K" in the optical drive bay.
  15. Dell XPS 14 L401X Keyboard Replacement: 15 단계, 이미지 1/2 Dell XPS 14 L401X Keyboard Replacement: 15 단계, 이미지 2/2
    • Remove (2) 4.5mm screws with JIS 1 screwdriver marked by the letter "K"in the hard drive bay.
  16. Dell XPS 14 L401X Keyboard Replacement: 16 단계, 이미지 1/2 Dell XPS 14 L401X Keyboard Replacement: 16 단계, 이미지 2/2
    • Remove (2) 4.5mm screws with JIS 1 screwdriver marked by the letter "K" near Battery
  17. Dell XPS 14 L401X Keyboard Replacement: 17 단계, 이미지 1/2 Dell XPS 14 L401X Keyboard Replacement: 17 단계, 이미지 2/2
    • Remove (1) 7.5mm screw with JIS 1 screwdriver marked by the letter "K" in the RAM bay.
  18. Dell XPS 14 L401X Keyboard Replacement: 18 단계, 이미지 1/3 Dell XPS 14 L401X Keyboard Replacement: 18 단계, 이미지 2/3 Dell XPS 14 L401X Keyboard Replacement: 18 단계, 이미지 3/3
    • Open the display to provide room for the palm rest to come out.
    • In the hard drive bay, push the "push" pad to lift up the palm rest.
  19. Dell XPS 14 L401X Keyboard Replacement: 19 단계, 이미지 1/3 Dell XPS 14 L401X Keyboard Replacement: 19 단계, 이미지 2/3 Dell XPS 14 L401X Keyboard Replacement: 19 단계, 이미지 3/3
    • Disconnect the track pad cable by flipping up the gray clamp and lifting the cable up.
  20. Dell XPS 14 L401X Keyboard Replacement: 20 단계, 이미지 1/2 Dell XPS 14 L401X Keyboard Replacement: 20 단계, 이미지 2/2
    • Disconnect the status bar cable by pulling the pin connector upward.
    • Finish lifting up the palm rest.
  21. Dell XPS 14 L401X Keyboard Replacement, Keyboard: 21 단계, 이미지 1/2 Dell XPS 14 L401X Keyboard Replacement, Keyboard: 21 단계, 이미지 2/2
    • Use a JIS 1 screwdriver to remove (2) 2.5mm screws located near the top of the keyboard.
  22. Dell XPS 14 L401X Keyboard Replacement: 22 단계, 이미지 1/3 Dell XPS 14 L401X Keyboard Replacement: 22 단계, 이미지 2/3 Dell XPS 14 L401X Keyboard Replacement: 22 단계, 이미지 3/3
    • Disconnect the keyboard's ribbon cable marked "A" by pushing out the two black tabs towards the ribbon cable.
    • Remove the cable from its connection terminal by sliding it out. Finish lifting up the keyboard and set it to the side.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Nicole Johnson
회원 가입일: 10/19/17
428 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team S4-G3, Julie Fall 2017 UMass Dartmouth, Team S4-G3, Julie Fall 2017 회원
UMASSD-JULIE-F17S4G3
3 회원들
안내서 11개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 5
전체 시간: 836
