주요 콘텐츠로 건너뛰기
Dell XPS 14Z L412Z Battery Replacement
필요한 것
  1. Dell XPS 14Z L412Z Battery Replacement, Back Panel: 1 단계, 이미지 1/1
    • Remove the back cover of the laptop by unscrewing eight 3.5mm screws using a Phillips #0 screwdriver.
  2. Dell XPS 14Z L412Z Battery Replacement: 2 단계, 이미지 1/2 Dell XPS 14Z L412Z Battery Replacement: 2 단계, 이미지 2/2
    • Using the plastic opening tool, pry up the back cover.
    • It is recommended to start from a corner and run the tool along the edge of the cover.
  3. Dell XPS 14Z L412Z Battery Replacement, Battery: 3 단계, 이미지 1/1
    • The battery is on the bottom left side.
  4. Dell XPS 14Z L412Z Battery Replacement: 4 단계, 이미지 1/1
    • Unscrew the five 4.5mm Phillips #0 screws around the battery.
  5. Dell XPS 14Z L412Z Battery Replacement: 5 단계, 이미지 1/2 Dell XPS 14Z L412Z Battery Replacement: 5 단계, 이미지 2/2
    • Using the plastic opening tools, carefully unplug the battery connection.
    • Then, plug your replacement battery into the new connection.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Colton Niewolny
회원 가입일: 02/15/18
411 평판
안내서 4개 작성하였습니다
UW Stout, Team S8-G3, Ogden Spring 2018 UW Stout, Team S8-G3, Ogden Spring 2018 회원
UWSTOUT-OGDEN-S18S8G3
4 회원들
안내서 6개 작성하였습니다
댓글 한 개
It worked smoothly! Less than 15 minutes. I used a OEM-battery, instead of an original one.
Jean Wallemacq - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 8
전체 시간: 2,912
