소개
The hard drive holds the entire memory for the device. Without the hard drive, your device is completely useless. It is fairly easy to replace. When taking off the plastic protection, make sure not to bend the metal parts of the plastic because it will be difficult to put back into place. For this guide you will need a plastic opening tool and a Phillips #0 screwdriver.
필요한 것
Remove the back cover of the laptop by unscrewing eight 3.5mm screws using a Phillips #0 screwdriver.
Locate the hard drive on the bottom right corner.
Unscrew the three 3.5mm screws with the Phillips #0 screwdriver.
