주요 콘텐츠로 건너뛰기
Dell XPS 15 9500 SSD Replacement
필요한 것
  1. Dell XPS 15 9500 SSD Replacement, Base Panel: 1 단계, 이미지 1개 중 1개
    • Remove the eight 3.0 mm screws from the bottom panel with a T5 Torx screwdriver.
  2. Dell XPS 15 9500 SSD Replacement: 2 단계, 이미지 2개 중 1개 Dell XPS 15 9500 SSD Replacement: 2 단계, 이미지 2개 중 2개
    • Gently wedge an opening tool in the gap between the base panel and chassis, and pry vertically around the perimeter until it releases from the chassis.
    • Lift the base panel up and away from the chassis.
  3. Dell XPS 15 9500 SSD Replacement, SSD: 3 단계, 이미지 1개 중 1개
    • Use a Phillips #000 screwdriver to remove the single 3.0 mm screw on the right side of the SSD.
  4. Dell XPS 15 9500 SSD Replacement: 4 단계, 이미지 1개 중 1개
    • Lift the card a few millimeters, then pull it directly out of its slot.
  5. Dell XPS 15 9500 SSD Replacement: 5 단계, 이미지 2개 중 1개 Dell XPS 15 9500 SSD Replacement: 5 단계, 이미지 2개 중 2개
    • If you wish to install a second SSD, there is an empty slot for an additional SSD underneath the copper cover. If you're just replacing the existing SSD, stop here.
    • Use a Phillips #000 screwdriver to remove the one 3.0 mm screw on the left side of the SSD slot.
    • Pull the cover out directly toward the left.
결론
작성자
3다른 기여자 명과 함께
Bryan Chung
회원 가입일: 10/18/19
437 평판
안내서 4개를 작성함
UC Santa Barbara, Team A-1, Bator Winter 2022 UC Santa Barbara, Team A-1, Bator Winter 2022 회원
UCSB-BATOR-W22SAG1
4 회원들
안내서 4개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 25
지난 30일: 76
전체 시간: 4,788
