주요 콘텐츠로 건너뛰기
Dell XPS 15 9510 Rear Panel Replacement
필요한 것
  1. Dell XPS 15 9510 Rear Panel Replacement, Rear Panel: 1 단계, 이미지 1/1
    • Make sure the laptop is powered off and unplug all cables before beginning any repair.
    • Remove eight 3 mm screws from the underside of the case using a T5 Torx screwdriver.
  2. Dell XPS 15 9510 Rear Panel Replacement: 2 단계, 이미지 1/1
    • The metal case of the XPS 15 9510 is extremely sharp, so be careful not to run your fingers along the edge when disassembling the laptop.
    • Wedge the case apart with a nylon spudger.
    • If the plastic one isn't possible to insert, use the metal spudger to carefully create a small gap first.
    • Slide spudger along each side of the laptop
  3. Dell XPS 15 9510 Rear Panel Replacement: 3 단계, 이미지 1/1
    • Lift the back panel of the laptop off and set it aside.
결론
Joseph Remondi
회원 가입일: 03/30/22
278 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 1-3, Mellen Spring 2022 UMass Dartmouth, Team 1-3, Mellen Spring 2022 회원
UMASSD-MELLEN-S22S1G3
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 26
전체 시간: 1,104
