주요 콘텐츠로 건너뛰기
Dell XPS 15 9530 Screen Replacement
필요한 것
  1. Dell XPS 15 9530 Screen Replacement, Base Cover: 1 단계, 이미지 1/3 Dell XPS 15 9530 Screen Replacement, Base Cover: 1 단계, 이미지 2/3 Dell XPS 15 9530 Screen Replacement, Base Cover: 1 단계, 이미지 3/3
    • Using a T5 Torx screwdriver, remove ten 3mm screws.
  2. Dell XPS 15 9530 Screen Replacement: 2 단계, 이미지 1/2 Dell XPS 15 9530 Screen Replacement: 2 단계, 이미지 2/2
    • Lift the plastic tab.
    • Remove two 3mm Phillips #0 screws under the plastic tab.
  3. Dell XPS 15 9530 Screen Replacement: 3 단계, 이미지 1/1
    • Lift the lower case off.
  4. Dell XPS 15 9530 Screen Replacement, Battery: 4 단계, 이미지 1/2 Dell XPS 15 9530 Screen Replacement, Battery: 4 단계, 이미지 2/2
    • Using a Phillips #0 screwdriver, remove the seven 3.5mm screws that secure the battery to the palm rest assembly.
  5. Dell XPS 15 9530 Screen Replacement: 5 단계, 이미지 1/1
    • Disconnect the battery cable from the system board.
    • Be sure to use a plastic tool, not a metal one.
  6. Dell XPS 15 9530 Screen Replacement: 6 단계, 이미지 1/1
    • Lift the battery off the chassis.
  7. Dell XPS 15 9530 Screen Replacement, SSD: 7 단계, 이미지 1/1
    • Pull lift tabs and remove the plastic that covers the hard drive to expose the hard drive.
  8. Dell XPS 15 9530 Screen Replacement: 8 단계, 이미지 1/2 Dell XPS 15 9530 Screen Replacement: 8 단계, 이미지 2/2
    • Using a Phillips #0 screwdriver, remove two 2.5mm screws that secure the SSD to the chassis.
  9. Dell XPS 15 9530 Screen Replacement: 9 단계, 이미지 1/1
    • Pull the SSD out parallel to the mainboard.
  10. Dell XPS 15 9530 Screen Replacement, Screen: 10 단계, 이미지 1/2 Dell XPS 15 9530 Screen Replacement, Screen: 10 단계, 이미지 2/2
    • Unplug the screen connector.
  11. Dell XPS 15 9530 Screen Replacement: 11 단계, 이미지 1/2 Dell XPS 15 9530 Screen Replacement: 11 단계, 이미지 2/2
    • Using a Phillips #0 screwdriver, remove the four 4mm screws holding in the screen hinges.
  12. Dell XPS 15 9530 Screen Replacement: 12 단계, 이미지 1/1
    • Pull chassis away from screen assembly.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Larissa Omura
회원 가입일: 04/04/19
743 평판
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 16
30일 전: 42
전체 시간: 1,437
